NEW FLECO 24 INCH & WBM 36 INCH 250-400 CLASS EXCAVATOR EXTREME DUTY DIGGING BUCKETS
Posted Date: Dec 17th, 2025 at 11:59 PM
5.0 stars 1K views
Price: $6000.00
The Fleco 250-350 Class Heavy Duty 24 Inch Trenching Bucket with CAT CB Linkage and 90 mm pin bores is a specific attachment designed to fit several Caterpillar excavator models, including the Cat 329. This bucket is built for heavy-duty trenching applications and adheres to OEM specifications.
Key Specifications
Feature Specification
CompatibilityCAT 324D/E, 326/D2/F, 329D/E, 330D2/F, 335F excavators
Width24 inches (610 mm)
Pin Diameter90 mm (both front and rear pins)
Linkage TypeFixed Cat CB Linkage
CapacityApproximately 0.52 cubic meters (0.68 cubic yards)
WeightApproximately 1018 kgs (2245 lbs)
TeethTypically includes 3 standard J-series style teeth
MaterialHeavy-duty AR400 steel on side edges and wear straps; A-572-50 steel shell
Key Features
  • Durable Construction: The use of AR400 steel provides superior strength and wear resistance, suitable for demanding conditions.
  • Application: Designed specifically for digging narrow, deep trenches while maintaining excellent breakout force.
  • OEM Specifications: The bucket is built to meet original equipment manufacturer specifications, ensuring proper fit and performance.
Certifications CE
Bucket Capacity (m³) 2
Operating Weight (Tons) 12–40
Location 1921 Lakeview Road Cambrisge Narrows
Availability For Sale
Condition New
Model DIGGING TRENCHING BUCKET
ALL-TRAC MACHINERY & LEASING Inc Feb 19th, 2026 at 19:48
Absolutely impressed with my Fleco extreme duty digging buckets! The 24″ and 36″ sizes fit perfectly on my 250–400 class excavator and handle tough digging with ease. Exceptional strength and build quality. Fast delivery and smooth purchase experience. Highly recommend these durable buckets and this seller to anyone in need of reliable attachments!
