XCENTRIC XC50 130+YARD PER HR JAW CRUSHER 400 - 650 CLASS EXCAVATOR 2 YARD BUCKET REPLACES A MOBILE CRUSHER FOR ONSITE CRUSHING
Posted Date: Jun 17th, 2026 at 03:27 AM
5.0 stars 537 views
Price: $70000.00
The World’s Most Advanced Excavator Jaw Crusher Bucket
Replaces $400,000+ Mobile Crushers – A Game-Changer for On-Site Crushing
Compact, Powerful & Efficient
  • 1 Man • 1 Machine • 1 Engine • 1 Lowbed Move
  • Dramatically reduces labor, equipment, and logistics costs
Superior to Traditional Mobile Crushers
  • Eliminates the need for a separate loader
  • Works efficiently in tight or restricted job sites
  • Output size adjustment in just 2–3 minutes
  • No conveyor belts to rip or fail
  • Minimal downtime – built for reliability, not repairs
Cost-Saving Advantages
  • Approximately 50% less fuel consumption
  • Approximately 50% lower insurance costs
  • Easy maintenance with no complex crusher systems
Strategic Investment
  • Replaces multiple machines on site
  • Faster setup and teardown
  • Ideal for demolition, quarrying, and remote operations
This bucket is a no-brainer for serious contractors looking to cut costs and boost efficiency.
Performance Highlights
  • Crushing output: 130+ cubic yards per hour
  • Crushes reinforced concrete (rebar included)
  • Handles hard granite and basalt
  • Processes wet or dry demolition debris
Replaces On-Site Jaw Crushers
  • Loads directly into trucks or stockpiles
  • Up to 10 tandem 13-cubic-yard dump trucks per hour
Adjustable Output Size
  • From 1/2"–1½" minus up to 5" product
  • Granulometry adjusted in under 5 minutes
  • Only two pins required to change jaw setting
Pricing
  • New replacement value: $250,000+ (6–7 week lead time)
  • Your price: $150,000 CAD – reduced to $70,000 CAD
  • Compare: Used XC29 (half the size) retailing at $145,000 CAD
  • Only used XC50 available worldwide
Technical Specifications
  • Model: Xcentric XC50
  • Year: 2020 – low-hour unit due to COVID shutdown
  • Original jaws over 80% | Original paint & decals
  • Carrier class: 38–65 ton excavators (ideal 45t+)
  • Weight: 6,250 kg
  • Jaw opening: 1100 mm x 500 mm
  • Crushing volume: 1.5 m³ (approx. 2 cubic yards per bucket)
  • Materials: HARDOX® 400, SSAB & STRENX
  • Stock #: XC50-0001
Current Pin Setup
  • Front pin: 100 mm but remove bushing for 110 mm  – 18.5" between ears
  • Rear pin: 100 mm – 16.5" between ears
  • 22.5" center-to-center pin spacing
  • Currently set up for KOMATSU PC 450LC BUT also works on Volvo EC480LC and EC380LC
Engineering Advantages
  • Patent-pending circular jaw motion for higher output
  • Crossed jaws crush wet or sticky material
  • Double-effect system reverses instantly if jammed
  • Anti-stagnation plate prevents blockages
Low Maintenance Design
  • Greasing interval every 200 hours
  • 80% fewer wear parts than conventional crusher buckets
  • No springs, spacers, toggles, or silent blocks
  • 40% less hydraulic oil required
  • Standard hydraulic components available worldwide
Environmental & Operational Benefits
  • Recycle material on site – reduce hauling and tipping fees
  • Lower environmental footprint
  • Low vibration and reduced excavator arm stress
Quick Outline:
The Xcentric XC50 is a high-performance excavator crusher bucket for large excavators (around 40-70 tons) designed to crush rock and recycle materials on-site, offering high production (130+ yards/hr), circular jaw movement for wet material, minimal maintenance (200h grease intervals), and features like an anti-stagnation plate and Hardox 400 construction for profitability and durability, turning your excavator into a mobile processing plant.
Key Features & Benefits:
  • High Production: Achieves over 130 cubic yards per hour by utilizing a high-inertia power train and circular jaw movement.
  • Handles Wet Materials: The circular motion and cross-top jaws bite and drag wet material through the crusher, preventing clogging.
  • Minimal Maintenance: Long intervals (e.g., 200 hours) between greasing reduce downtime.
  • Anti-Stagnation Plate: Patented design stops large pieces from getting stuck, ensuring continuous flow.
  • Durable Construction: Built with Hardox 400 steel for longevity.
  • Granulometry Adjustment: Quick and simple system for changing output size (e.g., 20mm to 210mm).
  • Double Effect Hydraulics: Allows for reversing the jaw movement to clear jams without emptying the bucket.
Target Excavator Size:
  • Designed for larger excavators, typically in the 40 to 70-ton class (or 52-70 tons as per some specs).
How it Works:
It attaches to your excavator, transforming it into a mobile crushing plant, allowing you to crush rock or concrete directly on-site, reducing trucking costs and creating usable aggregate.
Documentation & Videos
Location & Shipping
  • Located in Cambridge Narrows, New Brunswick
  • Fast Canada-wide shipping available
  • 12,000 lb 4WD forklift on site – we load your carrier
Contact – Serious Inquiries Only
Frank Rayner
Phone / Text / WhatsApp: 604-476-7777
Toll-Free: 1-833-693-9323
Email: [email protected]
Website: www.alltrac.co
Please no “Is this still available?” messages.
If the listing is live, the item is available.
Construction – Heavy Equipment – Operating Weight 6250
Construction – Heavy Equipment – Machine Length 2.8
Construction – Heavy Equipment – Bucket/Attachment Capacity 2
Construction – Heavy Equipment – Engine Power 175
Construction – Technical Specifications 130 YARDS PER HR
Construction – Location CAMBRIDGE NARROWS NB
Construction – Model / Part Number XC50 EXCENTRIC
Ashiq Mustafa Feb 19th, 2026 at 07:28
TOP... XCENTRIC XC50 130+YARD PER HR JAW CRUSHER 400 - 650 CLASS EXCAVATOR 2 YARD BUCKET REPLACES A MOBILE CRUSHER FOR ONSITE CRUSHING
