Werk-Brau D-LOCK Hydraulic 180 Degree Tilt Coupler 100-140 CLASS - $8,000 (CAMBRIDGE NARROWS NB)
Posted Date: Feb 20th, 2026 at 05:54 AM
Thumb 1 Thumb 2 Thumb 3 Thumb 4 Thumb 5 Thumb 6 Thumb 7 Thumb 8 Thumb 9 Thumb 10 Thumb 11 Thumb 12 Thumb 13 Thumb 14 Thumb 15 Thumb 16
5.0 stars 414 views
Price: $8000.00
Werk-Brau D-LOCK D-Lock Hydraulic Tilt Coupler FITS EXCAVATORS C/W 65 MM PINS
WAS BUILT FOR AND USED ON A JOHN DEERE 135G EXCAVATOR
BUILT THE 25TH DAY OF 5TH MONTH OF 2022
As new low hour unit used 1 job gives another 18 inches of 180 degree tilting to your excavator reach
LOW HOUR TAKE OFF C/W HYDRAULIC HOSES - READY TO MOUNT AND WORK
WAS FROM John Deere 135G RTS WITH THE FOLLOWING DIMENSIONS
PINS SIZE - 2.56 INCH OR 65 MM
DISTANCE BETWEEN EARS -10.10 INCH OR 2.56 MM
FITS ANY OF THE FOLLOWING INCLUDING:
Case CX130
Case CX135SR
Caterpillar 311C
Caterpillar 312B
Caterpillar 312C
Caterpillar 314C LCR
Daewoo SOLAR 130LC-V
Daewoo SOLAR 140LC-V
Hitachi EX 110-5
Hitachi Zaxis 120
Hitachi Zaxis 135US
John Deere 120C
John Deere 135C RTS
Kobelco 115SRDZ
Kobelco 135SRLC
Komatsu PC 100-6
Komatsu PC 120-6
Komatsu PC 128US-2
Komatsu PC 128UU-2
Komatsu PC 138USLC-2
Link-Belt 130LX
Link-Belt 135SA
Link-Belt 2650 QUANTUM
New Holland EH130
Takeuchi TB1140
Terex TXC 140LC-1
Features:
THIS UNIT FEATURES:
Automatic front lock – Locks the front pin in the event the rear pin is not secured
Multi-pin centers, picks up all attachments in the same weight class with the same pin diameter
Highly visible front lock indicator
Triple sealed actuator
Safety system does not rely on gravity
Dual pin lock – Locks both front and rear pins in the event of loss of engagement force
Unlock process is designed to release only when the operator intends to do so, in a controlled and safe manner
Simple yet safe unlock procedure eliminates accidental releases
Compact design – Improving machine performance
No greasing or lubrication required
Construction – Model / Part Number 180 Degree Tilt Coupler 100-140 CLASS
Construction – Year of Manufacture 2022
Construction – Condition Used
Construction – Attachment – Pin Size 65 MM
Construction – Attachment – Weight 800
Construction – Attachment – Capacity 1
Mark Henry Feb 23rd, 2026 at 14:47
I purchased the Werk-Brau D-Lock Hydraulic 180° Tilt Coupler (100-140 Class) from Alltrac and I couldn’t be happier with the experience. From start to finish, the process was smooth and professional. The coupler itself is a well-built, reliable attachment that delivers what it promises — it offers robust 180° tilt capability and is engineered for safety and performance with features like automatic front locking, dual pin locks, and a virtually maintenance-free design. It makes switching and tilting attachments quick and secure, which has saved me a lot of time on the job site. What impressed me most was dealing with Alltrac. Communication was clear and timely, and the unit was exactly as described — low hours and ready to mount. I highly recommend both the product and Alltrac as a trustworthy seller. I’ll definitely be doing business with them again!
