KOMATSU PC400 – PC490 ESCO® HDP Plus V Excavator Bucket Complete with (2) ESCO® Top Box Rippers - ESCO EXTREME DUTY TWIST LOCK TEETH
Posted Date: Jun 15th, 2026 at 07:54 PM
5.0 stars 675 views
Price: $12000.00
KOMATSU PC400 – PC490 ESCO® SXDP Plus V Excavator Bucket
The ESCO® SXDP Plus V Excavator Bucket with top box rippers and Extreme Duty Twist Lock Teeth is a heavy-duty, application-specific attachment designed for Komatsu PC400 to PC490 excavators operating in tough conditions like blasted rock, SandStone, Shale, solid Permafrost,  compacted soils, dense clay, or loosely embedded rock.
It is a Goldminers Dream Bucket for ripping and loading the ripped material without ripper to bucket cahngerds required.
Key Features and Specifications
  • SXPD Plus Construction: This version includes high-strength T-1 steel side plate reinforcements for enhanced structural integrity and durability in demanding applications.
  • V-Bottom Design: The V-shape is specifically intended for difficult trenching work in hard-to-penetrate materials such as shale or frozen ground, aiding in penetration and material breakup.
  • Triple Taper Design: The bucket's profile promotes faster, fuller loading and cleaner dumping, which improves productivity and reduces cycle times and fuel consumption.
  • ESCO Top Box Rippers: The inclusion of two rippers allows the material to be broken up prior to excavation, reducing wear and tear on the bucket and the machine itself, which lowers maintenance costs.
  • Extreme Duty Twist Lock Teeth: These use the ESCO Ultralok® system, a high-performance, two-piece tooth system that is hammerless, simplifying maintenance and ensuring excellent penetration and reliability. The specific "Extreme Duty" tooth profile is likely suited for highly abrasive and high-impact conditions.
  • Compatibility: The attachment is specifically designed to fit Komatsu PC400, PC450, and PC490 series excavators, ensuring proper fitment and performance.
Bucket Overview
  • Extreme-duty ESCO® SXDP Plus V-shaped excavator bucket
  • Designed for Komatsu PC400 to PC490 class excavators
  • V-shaped Tiger Tooth configuration
  • Built for the toughest materials:
    • Blasted rock
    • Sandstone
    • Shale
    • Limestone
    • Coal
    • Extreme frost conditions
  • 36-inch width
  • 2+ yard capacity
  • Ready to work – no lead time
New Replacement Cost
  • New cost from ESCO (bucket + rippers): Over $35,000 USD
  • Additional costs:
    • Approximately 6 months lead time
    • Shipping
    • Tariffs
  • Your price for this ready-to-work setup: $12,000 CAD
Product Specifications – ESCO® SXDP Excavator Buckets
  • Machine class: PC400 - PC450 - PC 490 KOMATSU
  • DUE TO THE DESIGN OF THE ESCO EAR SYSTEM THEY CAN EASILY BE LINE BORED TO FIT ANY 400 - 550 CLASS EXCAVATOR ( Width Between Ears Has Room To Go To 18+ Inches )
  • ESCO® SXDP buckets are field-proven for durability and performance
  • Super extreme-duty plate lip bucket
  • Custom wear packages available for abrasive applications
Standard ESCO® Bucket Features
  • Tough T-1 steel plate lip
  • Full bottom wear runner
  • Strong formed beam for torsion resistance
  • Triple-taper basket for:
    • Fast, full loading
    • Clean dumping on every pass
  • One-piece side reinforcing plates for structural integrity
  • Market-leading Ultralok® tooth system for excellent penetration
  • Optional lip centre and wing shrouds for added protection
ESCO® SXDP Excavator Bucket – Features & Benefits
  • Cast shrouds for side wear protection
  • ESCO® AR400 full bottom wear runner and side wear strips
  • Tough T-1 side reinforcing plates
  • Lip and beam gussets to strengthen corners
  • Full cast wear protection:
    • Lip shrouds
    • Wing shrouds
    • Corner wear shoes
  • Chisel points for penetration and extra strength
Product link:
https://www.global.weir/product-catalogue/construction-attachments/excavator-buckets/esco-sxdp-buckets/
PLUS (2) ESCO® Tool Box Rippers
Product link:
https://www.global.weir/product-catalogue/construction-attachments/esco-tool-box-rippers-for-hydraulic-excavators/
ESCO® Tool Box Ripper Description
  • Compact hydraulic excavator attachment mounted behind the bucket
  • Designed to break up:
    • Rock
    • Frozen ground
    • Other hard-to-penetrate materials
  • Ideal for:
    • Construction
    • Mining
    • Demolition
  • Improves efficiency and reduces bucket wear
  • More versatile than large, aggressive rippers
  • Eliminates frequent attachment changes
ESCO® Tool Box Ripper Benefits
  • Breaks material prior to excavation
  • Reduces wear and tear on:
    • Buckets
    • Machines
  • Lowers maintenance costs
  • Improves machine availability
  • Manufactured from top-quality materials
  • Built for the toughest conditions
  • Ideal for occasional ripping applications
  • Perfect for demolition to loosen material and prevent bucket damage
  • Shanks are easily pinned into a permanently mounted base on the back of the bucket
Location & Availability
  • Bucket is located at our yard in Cambridge-Narrows, New Brunswick
  • Ready to ship or pick up immediately
Contact
Frank
📞 604-476-7777
Construction – Brand / Manufacturer ESCO
Construction – Model / Part Number EXRETE DUTY RIPPING BUCKET
Construction – Technical Specifications Extre Duty V Trenching and Buld Digging
Construction – Attachment – Pin Size 100 MM FRONT 100 MM REAR
Construction – Attachment – Weight 6000
Construction – Attachment – Width 36
Construction – Bucket – Capacity 2.5
Construction – Bucket – Width 36
Bushra Ali Feb 12th, 2026 at 16:43
Thrilled with my ESCO HDP Plus V excavator bucket! The heavy‑duty design and Extreme Duty Twist Lock Teeth make digging and ripping rock and tough ground easy. It fits my Komatsu perfectly and the included top box rippers save time and effort. Outstanding performance and reliability — highly recommended!
