Werk-Brau D-LOCK D-Lock Hydraulic Tilt Coupler FITS EXCAVATORS C/W 65 MM PINS BUILT FOR AND USED ON A JOHN DEERE 135G EXCAVATOR
Posted Date: May 9th, 2026 at 12:25 AM
5.0 stars 468 views
Price: $10000.00
WAS BUILT FOR AND USED ON A JOHN DEERE 135G EXCAVATOR
UNIT BUILT THE 25TH DAY OF MAY 2022 - LOW-HOUR TAKE-OFF C/W HYDRAULIC HOSES - READY TO MOUNT AND WORK - ANOTHER 18 INCHES OF 180 DEGREE TILTING REACH WITH A DOUBLE LOCKING PIN GRABBER COUPLER THAT GRABS MULTIPLE ATTACHMENTS
BUILT FOR AND WAS FROM John Deere 135G RTS WITH THE FOLLOWING DIMENSIONS
PINS SIZE - 2.56 INCH OR  65 MM
DISTANCE BETWEEN EARS -10.10 INCH OR 2.56 MM
 FITS ANY OF THE FOLLOWING, INCLUDING:
Case CX130
Case CX135SR
Caterpillar 311C
Caterpillar 312B
Caterpillar 312C
Caterpillar 314C LCR
Daewoo SOLAR 130LC-V
Daewoo SOLAR 140LC-V
Hitachi EX 110-5
Hitachi Zaxis 120
Hitachi Zaxis 135US
John Deere 120C
John Deere 135C RTS
Kobelco 115SRDZ
Kobelco 135SRLC
Komatsu PC 100-6
Komatsu PC 120-6
Komatsu PC 128US-2
Komatsu PC 128UU-2
Komatsu PC 138USLC-2
Link-Belt 130LX
Link-Belt 135SA
Link-Belt 2650 QUANTUM
New Holland EH130
Takeuchi TB1140
Terex TXC 140LC-1
Volvo EC 145
Werk-Brau manufactures all attachments to O.E.M. specs for all makes and models of excavators, mini-excavators, and backhoes.
Features:
THIS UNIT FEATURES:
Automatic front lock – Locks the front pin in the event the rear pin is not secured
Multi-pin centers, picks up all attachments in the same weight class with the same pin diameter
Highly visible front lock indicator
Triple sealed actuator
Safety system does not rely on gravity
Dual pin lock – Locks both front and rear pins in the event of loss of engagement force
Unlock process is designed to release only when the operator intends to do so, in a controlled and safe manner
Simple yet safe unlock procedure eliminates accidental releases
Compact design – Improving machine performance
No greasing or lubrication required
Only requires four hydraulic lines
Up to 180 degrees of tilt
Fully guarded hoses
WATCH THE WERBRAU VIDEO (copy and paste)
https://werk-brau.com/wp-content/uploads/2023/09/tilt-coupler-Original.mp4?_=1
AND THE PDF FILE
https://werk-brau.com/wp-content/uploads/2020/03/NOBLEED-Individual-Tilting-Coupler.pdf
    Only requires two hydraulic lines
WATCH THE WERBRAU VIDEO FOE THE DLOCK COUPLER
https://youtu.be/c2Q7Kw4o_JA
*  The simple, easily serviceable design of the D-Lock combined with world leading safety features makes the
D-Lock the safest coupler on the market today.
 The D-Lock Coupler is dual locking, meaning attachments remain securely engaged on both pins in the event of loss of engagement force.
A compact design of only seven moving parts (fewest in the industry), requiring only two hoses, no greasing and no complicated operating
sequence to follow are just a few of the features which put the D-Lock at the forefront of coupler performance worldwide.
D-LOCK® COUPLER U.S. patent no. 9,677,245
When safety is paramount Automatic front lock – Locks the front pin in the event the rear pin is not secured
Multi pin center, picks up all attachments in the same weight class with the same pin diameter OR less
Highly visible front lock indicator Safety system does not rely on gravity
Simple yet safe unlock procedure eliminates accidental releases.
Unlock process is designed to release only when the operator intends to do so, in a controlled and safe manner, and prevents accidental release
 Patented slide lock design*
Compact design – Improving machine performance Only requires two hydraulic lines Fewest parts in industry (8)
No greasing or lubrication required Available for all machines from 1.5 to 120 tons
Construction – Model / Part Number WERBRAU HYDRAULIC TILT COUPLER
Construction – Location CAMBRIDGE NARROWS NB
Construction – Attachment – Pin Size 65 / 2.56
Construction – Attachment – Weight 895
ALL-TRAC MACHINERY & LEASING Inc Feb 13th, 2026 at 20:06
I’m extremely satisfied with the Werk-Brau D-Lock Hydraulic Tilt Coupler. It fits my John Deere 135G perfectly, is built with top-quality materials, and provides smooth, safe operation. Installation was easy, and the dual-lock system gives me confidence when switching attachments. Highly recommend this product for any excavator owner!
