$68K of HENSLEY HPX 400-490 KOMATSU EXTREME DUTY 30-46-70 IN BUCKETS = TAKE COMPLETE SET OR SEPERATE
Posted Date: Jun 11th, 2026 at 06:20 PM
5.0 stars 1.2K views
Price: $25000.00
Complete Set of Extreme Duty Excavator Buckets – Like New 🔹
Take the complete set of mint-condition, low-hour buckets valued at $68,000 CAD for only $25,000 CAD
  • Hensley / ADCO HPX Extreme Duty AR400 steel buckets
  • Removed from a Komatsu PC450LC-8
  • Excavator has less than 7,300 hours
  • Used primarily for grapples and demolition processors
  • Buckets are as new with new teeth installed
  • USA-built, high-quality steel
🔧 Compatibility
  • Fits Komatsu PC400 to PC490
  • Fits 400–550 class excavators
  • Compatible with Geith or other quality pin grabber couplers
🧰 Bucket Set Includes (3 Buckets)
1️⃣ 70” Cleanup / Bulk Loading Bucket
Rare, Toothed 4-Yard Heaped – Deep Cleanup Bucket
  • Width: 70 inches
  • Deep design for loading trucks over the rear with no spillage
  • Ideal for:
    • Concrete
    • Rock
    • Limestone
    • Shale
    • Sandstone
    • Coal
  • Multiple teeth spaced side-by-side for:
    • Superior strength
    • Aggressive cutting
    • Smooth excavation finish
  • Easily rips and loads crushed concrete and rock
  • Used to load out bulk rock and concrete (3-bucket trucks)
Original cost: $20,000 USD
Your price: $10,000 CAD
2️⃣ 46” Extreme Duty Digging Bucket
  • Complete with new Komatsu teeth
  • Side cutters installed
  • Extensive hard-surfacing welding completed
  • Ready to work immediately
Price: $10,000 CAD
3️⃣ 30” Extreme Duty V-Ripper Bucket
  • Complete with all new Tiger teeth
  • Bucket is as new
  • Ready to work
Price: $8,000 CAD
💰 Package Deal
Take all three rare Extreme Duty buckets for only:
$25,000 CAD
📞 Contact: Frank
📱 Phone: 604-476-7777
🔩 Hensley Bucket Overview
Hensley offers a wide range of buckets designed to deliver:
  • Improved productivity
  • Greater structural strength
  • Longer service life
  • Custom options available for specific applications
🔗 HP / HPS / HPX Series:
https://www.hensleyind.com/hp-series/
🪨 Hensley Bucket Types & Applications
HP – Heavy Duty Bucket
Standard Features
  • Dual taper / dual radius design
  • One-piece T-1 blade & lip
  • 400 BHN side kick plate
  • Full 400 BHN bottom wear plate
  • One-piece side plate
  • Strike-off assemblies
  • Formed beam upper structure
Recommended Applications
  • Soil
  • Loam
  • Coal
  • Sand
  • Gravel
HPS – Severe Duty Bucket
Additional Features
  • Horizontal wear strips (400 BHN)
  • High silica sand
  • Caliche
  • Sandstone
  • Well-shot limestone
  • Shale
HPX – Extreme Duty Bucket
Additional Features
  • Upper & lower side kick plates (400 BHN)
  • Increased material thickness in high-wear areas
  • Cast heel wear shrouds
  • Optional bimetallic wear products
  • Granite
  • Ore
  • Limestone
“V” Bucket
🔗 https://www.hensleyind.com/specialty-buckets/
Standard Features
  • Original “V” bottom design
  • T-1 blade
  • Specially designed teeth and adapters
  • Ideal for utility and trench work
  • Limestone
  • Caliche materials
  • Fracturable materials
  • Deep-frost compacted soils
Ditch Cleaning Bucket
Standard Features
  • Wide, shallow basket design
  • T-1 lip
  • Bottom wear strips
  • Optional bolt-on edge
  • Ditch cleaning
  • Loam
  • Sand
Availability For Sale
Compatible Machine Excavator
Attachment Type Bucket
Mount Type Pin-on
Company/Maker Website https://www.hensleyind.com/hp-series/
Certifications CE
Location 1921 Lakeview Road Cambrisge Narrows
Condition Rebuilt
Model DIGGING TRENCHING - CLEANUP BUCKETS
ALL-TRAC MACHINERY & LEASING Inc Feb 19th, 2026 at 19:46
Absolutely thrilled with my purchase from this listing — the Hensley HPX extreme duty buckets are built tough, high‑quality, and ready to work right away. Excellent value for such durable Komatsu‑compatible buckets. Delivery and seller communication were smooth. Highly recommend this product and seller to anyone needing reliable heavy equipment attachments!
