How to choose control transformers
Posted Date: Mar 19th, 2026 at 01:29 PM
0.0 star 241 views
Our single‑phase industrial control transformers from steptransformer.com are engineered to provide stable, isolated control power for demanding industrial environments. Available in ratings from 500 VA to 10 kVA, they support primary voltages including 110, 120, 208, 220, 230, 240, 380, and 480 VAC, and are designed for reliable 50/60 Hz dual‑frequency operation in continuous‑duty applications.
Built with high‑conductivity oxygen‑free copper windings and low‑loss grain‑oriented silicon steel cores, these transformers ensure high efficiency, low heat rise, and strong voltage regulation even under fluctuating loads. Precision‑engineered cold‑pressed terminals and reinforced insulation systems enhance safety, improve durability, and protect against short circuits, voltage spikes, and electrical breakdown.
Featuring flexible multi‑tap primary and secondary windings, these transformers allow easy voltage adjustment to match a wide range of control requirements. Common secondary outputs include 12, 24, 110, 115, 120, and 240 VAC, making them ideal for powering relays, contactors, solenoids, PLCs, HMIs, sensors, timers, and other sensitive control components.
Their compact, rugged, panel‑mountable design fits easily into standard control cabinets, machinery enclosures, and space‑constrained industrial setups. The reinforced construction withstands vibration, shock, dust, and humidity, making them suitable for use in automation, robotics, HVAC, machine tools, material handling, welding equipment, air compressors, rail systems, power distribution, and new energy applications.
By providing full galvanic isolation between main power and control circuits, these transformers eliminate ground loops, reduce electrical noise, and block harmful harmonics and transients. This protection improves system stability, extends equipment life, enhances operational safety, and reduces unplanned downtime and maintenance costs.
Fully customizable to meet specific project needs, these control transformers can be tailored for unique voltage combinations, VA ratings, terminal configurations, insulation class, lead lengths, mounting styles, and environmental protections. Whether for new installations, retrofits, export equipment, or custom control systems, they deliver consistent performance, high efficiency, and long‑term reliability to support safe and uninterrupted industrial operations.
