How to Build a Custom LLM Chatbot in 48 hr
Posted Date: Feb 19th, 2026 at 05:30 PM
0.0 star 325 views
Build and deploy a custom LLM chatbot in just 48 hours using MirrorFly’s enterprise conversational AI infrastructure. This solution helps developers and businesses create scalable, secure, and production-ready LLM based chatbot solutions for web and mobile applications.
A modern LLM chatbot solution uses Large Language Models, Retrieval Augmented Generation (RAG), and real time communication to deliver intelligent, context aware conversations. Whether you want to build a chatbot using LLM, integrate enterprise knowledge, or create an AI assistant similar to ChatGPT, MirrorFly provides complete deployment flexibility and infrastructure control.
Core Features and Capabilities
• Build a fully functional custom LLM chatbot platform with real time messaging
• Integrate leading LLM providers like OpenAI, Claude, Gemini, and Llama
• Implement retrieval augmented generation using retrieval chain and vector database integration
• Create intelligent conversational workflows with contextual memory
• Enable real time chat, voice, and video communication inside chatbot interactions
• Deploy secure and scalable LLM chatbot solutions for enterprise applications
• Maintain full ownership with on premise, cloud, or hybrid deployment
Advanced LLM Chatbot Infrastructure
• Context aware conversational intelligence using retrieval chain architecture
• Vector database integration for knowledge retrieval and semantic search
• Multi user chatbot support with real time synchronization
• Secure authentication, encryption, and enterprise grade access control
• Scalable infrastructure designed for production ready chatbot deployment
• Complete flexibility for custom LLM integration into existing applications
Business and Developer Use Cases
• Enterprise customer support automation
• AI virtual assistants for SaaS platforms
• Internal knowledge assistants using private company data
• AI chatbot integration for healthcare, fintech, telecom, and ecommerce
• Developer solutions to build and deploy LLM chatbot applications
Deployment and Integration Flexibility
MirrorFly provides complete control to deploy your LLM based chatbot solution according to your infrastructure needs:
• On premise deployment for maximum data privacy
• Cloud deployment for scalability and faster rollout
• Hybrid deployment for performance and flexibility
This solution enables organizations to create, integrate, and scale custom LLM chatbot solutions, making it ideal for businesses building secure, intelligent, and enterprise ready conversational AI platforms.
Technology – AI Service Type AI Chatbots
Technology – AI Deployment Type On-Premise
