Hex Nuts Hex Head Bolts Fasteners Strut Channel Fittings manufacturers exporters suppliers in India wwwhindustanengineersorg 919888542291
Posted Date: Jun 25th, 2026 at 12:10 PM
Thumb 1 Thumb 2 Thumb 3 Thumb 4 Thumb 5 Thumb 6 Thumb 7 Thumb 8 Thumb 9 Thumb 10 Thumb 11 Thumb 12
0.0 star 207 views
Price: $1000.00
Hindustan Engineers are manufacturing and export high tensile fasteners products range includes Hex Nuts, Hex Bolts, Hex Bolts, Hex Head Bolts, Hexagonal Bolts, Hexagon Bolts, Hex Nuts, Hex Head Nuts, Hexzgonal Nuts, Hexagon Nuts, High Tensile Fasteners, Precision Fasteners, Allen CSK Bolts, Plain Washers, Spring Washers, Anchor Foundation Bolts, Roofing Bolts, Eye Bolts, UBolts, Scaffoldings / Couplers, Road Crash Barrier Fasteners, Drywall Screws, Sheet Metal Screws, Wooden Screws, Wood working Screws, Threaded Rods Thread Studs, Fan Bolts / Fan Clamps etc. We are also manufacturers & exporters of All DIN Standard Fasteners which includes 8.8 Grade Hex Bolts, 8.8 Grade Hex Nuts, Hot dip Galvanizing Fasteners, High Tensile Bolts DIN 931 DIN 933, High Tensile Nuts DIN 934, DIN 6921 Flange Bolts, DIN 603 Carriage Bolts, ASTM A325 Structural Bolts, DIN 931 / ISO 4014, Hex Bolts DIN 933 Hex Bolts / ISO 4017, Hex Bolts DIN 933 SZ Hex Bolt / ISO 4017, Hex Bolt DIN 960 / ISO 8765 / EN 28765, Hex Bolts DIN 961 / ISO 8676 / EN 28676, Hex Bolts DIN 7990 Hex Bolts, DIN 6914 Hex Bolts / ISO 7412, Hex Bolts ASTM A307 Grade Heavy Hex Bolt, DIN 934 Hex Nuts / ISO 4032 Hex Nuts, DIN 439 Hex Nuts / DIN 936 Hex Nuts, IS 1363 Part 3 Hex Nuts, IS 1364 Part 5 Hex Nuts, DIN 6915 Hex Nuts / ISO 7414 Hex Nuts, IS 6623 Hex Nuts, DIN 6330 Hex Nuts, ASTM F594 Nuts, Din 125A Washer / ISO 7089 Washers, Din 125B Washer / ISO 7090 Washers, DIN 126 Washer / ISO 7091 Washers, DIN 9021 Washers, IS 2016 Washers, DIN 6916 High Strength Structural Washer, DIN 127A Spring Washer, DIN 127B Spring Washer, ASTM F436 Washer etc., Our Strut Support Systems Products Range Includes Channel Brackets / Channel Fittings, Channel Accessories, Channel Nuts, Spring Channel Nuts, Short Spring Channel Nut, Long Spring Channel Nuts, Conical Spring Channel Nuts, Top Spring Channel Nut, Hammer Head Channel Nuts, Square Washers, Flat Plate Brackets, Flat L bracket, T bracket, Angle bracket, Delta bracket, Welded Gusset bracket, Obtuse bracket, Z bracket, C bracket, Top Hat bracket, Base Plates, Internal External Connectors, Wing brackets, Strut Channels, Plain Channels, Slotted Channels, Cantilever Arms, Slotted Cantilever Arms, pipe clamps, single pipe clamp, clevis clamp and clamp accessories, Castings Strut Pipe Clamps, Clevis Hanger, channel Purlin Clamps, Toe Beam Clamp, Heavy Beam Clamp, Z type Beam Clamp, Window Brackets, Beam Clamp with U Bolt, Malleable Iron Beam Clamp, Post Base, Purlin Clamp, Sheet Metal Beam Clamp, Purlin Clamps, Wedge Nut, Back Plate with Dual Nut M8 + M10, Bush & Check Nut, Saddle Clamp Steel BZPP Clips, PVC Strut End Cap, Hex Bolts, U - Bolts, Long Coupling Nuts, Threaded Rod / Bar etc. Website: https://www.hindustanengineers.org Mobile: +91-9888542291
Price per Unit 100
Monthly Reach / Impressions 597
Campaign Duration 60
Target Market HINDUSTAN ENGINEERS
Ad Type Digital
Lead Time (Days) 8
Delivery / Shipping Available Yes
Unit Type Pieces
MOQ (Minimum Order Quantity) 100
Email [email protected]
Business / Supplier Name HINDUSTAN ENGINEERS
Website https://www.hindustanengineers.org
Contact Person Prabhjeet Singh
Condition Used
