FLECO HEAVY-DUTY 24” TRENCHING BUCKET — 250–350 CLASS
Posted Date: May 21st, 2026 at 09:00 PM
5.0 stars 534 views
Price: $6000.00
🔧 BUCKET DETAILS
  • Brand: Fleco Attachments
  • Bucket Type: Heavy-Duty Trenching Bucket
  • Width: 24 Inch
  • Excavator Class: 250–350
  • Designed for: CAT 329 Excavators
  • Linkage: CB Linkage
  • VIN #: 44224
⚙️ FITMENT & COMPATIBILITY
  • Fits CAT 329 / 329E
  • Fits any 240–350 class excavator with hydraulic pin grabber coupler
  • Pin & Boss Dimensions:
    • Stick Pin: 90 mm
    • Link Pin: 90 mm
    • Center-to-Center Pin Boss: 495 mm
    • Inside-to-Inside Pin Boss Spacing: 390 mm
🛠️ CONSTRUCTION & MATERIALS
  • Built with Heavy-Duty AR400 Steel
  • AR400 wear steel used on:
    • Side wear plates
    • Cutting edge
    • Mounting brackets
    • Reinforcing wear bars
  • Bucket shell: A-572-50 rolled structural steel
  • AR400 offers significantly higher wear resistance than T1 steel
✅ STANDARD FEATURES
  • Built to OEM specifications
  • Thick wear straps & wear pads
  • Standard J-Series style teeth
  • Flat boot trenching wear plate
  • Integrated D-Ring
🔩 OPTIONAL FEATURES
  • Side cutters (12K lb class & up)
  • Dead pins
🏗️ APPLICATIONS
  • Trenching
  • Dirt & clay excavation
  • General utility digging
  • Construction & infrastructure projects
🏭 ABOUT FLECO ATTACHMENTS
  • Industry-leading manufacturer of high-quality excavator attachments
  • Known for durability, reliability, and performance
  • Engineered solutions tailored to real-world jobsite demands
  • All products rigorously tested to meet or exceed safety standards
  • Custom attachment solutions available
🔨 BUILT FOR MAJOR OEMs
Compatible with:
  • CAT, CASE, KOBELCO, SANY, JOHN DEERE, HITACHI, KOMATSU
  • TAKEUCHI, KUBOTA, LINK-BELT, VOLVO, HYUNDAI
  • LIU GONG, NEW HOLLAND, DOOSAN, JCB
  • SAMSUNG, DAEWOO, KAWASAKI, YANMAR, BOBCAT
Heavy-duty trenching bucket — ready to work, built to last.
Construction – Condition New
Construction – Serial Number 44224
Construction – Technical Specifications EXTREME DUTY 24 INCH TRENCING BUCKET
Construction – Attachment – Pin Size 90 mm
Construction – Attachment – Width 24
Construction – Attachment – Capacity 1.5
Construction – Bucket – Capacity 1.5
Construction – Bucket – Width 24
Mark Henry Feb 19th, 2026 at 17:38
I’m a satisfied client and I really like their machinery! The Fleco Heavy Duty 24" Trenching Bucket (250–350 Class) is rugged, reliable, and exactly what I needed for my projects. Great build quality and performs just as expected. The buying experience on EzeAD was smooth and trustworthy. Highly recommend this platform if you want to buy or sell quality heavy equipment with confidence!
