ESCO EXTREME DUTY 350-500 EXCAVATOR RIPPING- TRENCHING SHORING
Posted Date: Jun 11th, 2026 at 06:20 PM
Price: $6000.00
ESCO Extreme-Duty Cage / Pipeline / Ripping Bucket
Designed for shale & sandstone ripping with high-volume truck loading capability
Bucket Overview
Custom-built ESCO drop-center bucket
48” overall width
28” wide, 3-tooth center ripper section
Extreme-duty design for:
Pipeline and cage trenching
Shale and sandstone ripping
High-volume truck loading
Performance & Design Benefits
Drop-center design provides aggressive ripping performance
Allows shoring cages to sit over a 36” higher upper-cut ledge
Built to WorkSafe regulations
Often eliminates stacking two shoring cages in deeper trenches
Allows use of shorter cages in shallow trenches
Ideal for:
Cage trenching with reduced bedding material
Faster cycle times
High-capacity material handling
Digging Specifications
85” from center of stick pin to tip of ripper teeth
Provides 13” additional digging depth compared to standard buckets
Machine Fitment
100 mm pins
23” pin centers
17” between ears
Previously used on a Volvo EC480DL with pin grabber
Compatible with any excavator accepting these pin dimensions
Construction & Condition
Reinforced with additional T-1 plate steel
Extensive hard-surfacing applied
New teeth installed
Ready for:
Cage trenching
Extreme-duty ripping applications
Value
New ESCO price: Over $25,000 USD
Asking price: $6,000
Will pay for itself on the first shoring trenching job through:
Time savings
Reduced bedding material
Increased loading efficiency
Location
Located at our yard in Cambridge Narrows NB
Price just reduced for quick sale
Additional Equipment Available
Dromone hydraulic pin grabber couplers
HD 48” digging bucket
24” ESCO ripping bucket with new 100 mm pins
JD / Hitachi 350–400 Dromone hydraulic quick coupler
(See other listings for pricing details)
| Certifications | CE |
| Boom Type | Standard |
| Bucket Capacity (m³) | 4 |
| Operating Weight (Tons) | 40–90 |
| Excavator Type | Large |
| Company/Maker Website | https://www.global.weir/product-catalogue/construction-attachments/excavator-buckets/ |
| Location | 1921 Lakeview Road Cambrisge Narrows |
| Operating Weight | 25–50 Ton |
| Condition | Rebuilt |
| Fuel Type | Diesel |
| Model | DIGGING TRENCHING BUCKET |
| Brand Name | Esco |
Fantastic Looking.. ESCO EXTREME DUTY 350-500 EXCAVATOR RIPPING- TRENCHING SHORING
