ESCO EXTREME DUTY 350-500 EXCAVATOR RIPPING- TRENCHING SHORING
Posted Date: May 21st, 2026 at 09:01 PM
0.0 star 650 views
Price: $6000.00
ESCO EXTREME-DUTY DROP CENTER BUCKET — HIGH VOLUME / PIPELINE / SHALE
🪨 APPLICATIONS
  • Pipeline & cage work
  • Extreme-duty shale & sandstone ripping
  • High-volume excavation
  • Truck loading
  • Trenching & shoring
🛠️ BUCKET DESIGN
  • ESCO Personalized Drop Center Bucket
  • Outside Width: 48 inches
  • Center Section: 28-inch wide, 3-tooth ripper
  • Designed for aggressive ripping while maintaining high material volume
  • Ideal for shale & sandstone with excellent truck-loading capability
✅ WORKSAFE COMPLIANT DESIGN
  • Drop-center allows extreme ripping over the center section
  • 36-inch higher upper-cut edge supports shelving brackets
  • Often eliminates the need for:
    • Two shelving brackets in deep trenches
    • Or allows shorter shelves in shallow trenches
  • Saves time, material, and setup costs
📏 DIGGING DEPTH & SIZE
  • 85 inches from stick pin center to tip of ripper teeth
  • Provides 13 inches MORE digging depth than standard buckets
⚙️ FITMENT DETAILS
  • Previously used on Volvo EC480DL
  • Bucket pin configuration:
    • 100 mm pins
    • 23 inches center-to-center
    • 17 inches between ears
  • Will fit any excavator accepting these pin dimensions
  • Originally run with hydraulic pin grabber coupler
🔩 CONDITION & UPGRADES
  • Additional T-1 plate steel reinforcement
  • Hard-surfaced wear areas
  • New teeth installed
  • Fully prepped for:
    • Cage work
    • Extreme-duty ripping
💰 VALUE & PRICE
  • New ESCO replacement value: $25,000+ USD
  • TAKE IT FOR: $8,000
  • Large volume = pays for itself on first job
  • Ideal for shoring, trenching, and truck loading with less bedding required
➕ OPTIONAL MATCHING EQUIPMENT (SEE OTHER ADS)
  • Dromone hydraulic pin grabber couplers to fit this bucket
  • HD 48” digging bucket — $12,000
  • 24” ESCO ripping bucket with new 100 mm pins — $4,000
  • JD / Hitachi 350–400 class Dromone hydraulic coupler — $6,000
📍 LOCATION
  • Langley, BC — Our Yard
  • Price just reduced to move quickly
  • Yard clearance due to retirement & relocation to NB
📞 CONTACT
Frank
📱 604-476-7777
🏭 FROM ESCO — XDP HEAVY-DUTY EXCAVATOR BUCKET
  • Designed for demanding overburden excavation
  • Excels in rock excavation & top-loading
  • Features include:
    • Lip & beam gussets for high-stress durability
    • One-piece T-1 steel reinforcing plates
    • 400 Brinell bottom runner wraps under lugs for full abrasion resistance and structural strength
Serious iron at a fraction of replacement cost — ready to work now.
Certifications CE
Boom Type Standard
Bucket Capacity (m³) 3
Dig Depth (ft) 24
Operating Weight (Tons) 40–90
Excavator Type Large
Company/Maker Website http://Esco Steel
Location 1921 Lakeview Road Cambrisge Narrows
Availability For Sale
Operating Weight 25–50 Ton
Condition Rebuilt
Model DIGGING TRENCHING BUCKET
Brand Name Weir - Esco
