EMGLO WHEELBARROW 3 HP 2 STAGE 200 PSI DEWALT PUMP PORTABLE COMPRESSOR
Posted Date: Jun 11th, 2026 at 06:21 PM
Thumb 1 Thumb 2 Thumb 3 Thumb 4 Thumb 5 Thumb 6 Thumb 7 Thumb 8 Thumb 9 Thumb 10 Thumb 11 Thumb 12 Thumb 13
5.0 stars 550 views
Price: $750.00
FOR SALE: EMGLO WHEELBARROW AIR COMPRESSOR – COMMERCIAL GRADE – LOW HOURS
🔥 Built for Demolition Sites – Fully Upgraded & Ready to Work
  • Make/Model: EMGLO with New DEWALT 2-Stage 200 PSI Pump (Pump alone retails for $1,100 USD / $1,500+ CAD)
  • Motor: 3 HP, 220V Single Phase, Induction Motor (Newer unit)
  • Airflow: 15 CFM @ 90 PSI / 11.5 CFM @ 200 PSI
  • Max Pressure: 200 PSI
  • Tank Capacity: 7.8 Gallon Wheelbarrow Style
  • Pump Type: Cast Iron, Oil-Lubricated, 2-Stage Piston Pump
  • Duty Cycle: Full Continuous Duty – Built for Jobsite Toughness
  • Voltage/Current: 240V AC / 13.5 Amps – Plug-and-play with cord and plug included
  • Dimensions: 42.5” L x 18.25” W x 24.75” H
  • Weight: Approx. 150 lbs
  • Noise Level: 85 dBA
  • Outlet Size & Type: 3/8” and 1/2” NPT, Female
💪 Built Tough – Not Chinese Junk
  • Purpose-Built: Designed specifically to meet the high-pressure needs of demolition and on-site trades
  • Powerful Output: Runs 5 framing guns, large air impacts, and high-demand tools
  • Painting-Ready: Can handle two paint guns simultaneously with steady airflow
  • Low Hours: Lightly used – over $3,000 CAD invested in build and upgrades
🔧 Additional Info:
  • Pump Life Expectancy: 5,000+ hours
  • Control Type: On/Off with Pilot Valve
  • Certified: CSA & UL Standards
🏁 Ready to Plug In & Test
Bring your hose and tools – Unit is fully functional on-site
📍 Located in BC – Owner Retiring and Leaving Province
📞 Frank: 604-476-7777
ALL-TRAC MACHINERY & LEASING Inc Feb 23rd, 2026 at 13:35
I’m extremely satisfied with the EMGLO Wheelbarrow 3 HP 2-Stage 200 PSI Dewalt Pump Portable Compressor — powerful, reliable, and perfect for heavy duty jobs. It starts easily, runs smoothly, and delivers excellent air pressure. Built sturdy and portable, it’s great for construction and workshop use. Highly recommend this compressor!
