Dump and Crane Truck – Dual Functionality for Maximum Efficiency
Posted Date: Jul 9th, 2025 at 05:53 AM
0.0 star 175 views
Price: $17000.00
🚛 Dump and Crane Truck – Dual Functionality for Maximum Efficiency
Heavy-Duty Dump Body & Hydraulic Crane | Built for Tough Jobs and Quick Lifts
🛠️ Truck Overview
  • Chassis: Medium to heavy-duty truck (Ford, Freightliner, International, Peterbilt, or similar)
  • Engine: Reliable diesel engine delivering strong torque and power
  • Transmission: Manual or automatic transmission suited for heavy loads and precise control
  • GVWR: Typically 26,000 to 66,000 lbs depending on chassis and configuration
  • Cab: Comfortable with PTO controls and operator-friendly features
🚚 Dump Body Features
  • Body Length: 12 to 16 ft steel dump bed for hauling soil, gravel, debris, and materials
  • Hoist: PTO-driven hydraulic hoist for fast and reliable dumping operations
  • Tailgate: Swing or barn-door style with secure locking mechanisms
  • Bed Condition: Reinforced steel with anti-slip coating and tie-down points
🏗️ Crane Features
  • Crane Type: Hydraulic knuckle boom or telescopic crane mounted behind cab or on bed
  • Lifting Capacity: Typically 5,000 to 15,000 lbs depending on crane model
  • Boom Reach: 15 to 40+ ft reach for versatile loading and placement
  • Controls: Manual lever or wireless remote controls for safe operation
  • Stabilizers: Hydraulic outriggers for stable lifts on uneven terrain
✅ Applications
  • Construction material hauling and placement
  • Landscaping and tree service work
  • Utility pole installation and maintenance
  • Debris removal and site cleanup
  • Municipal public works and maintenance projects
🔍 Condition & Details
  • Year: [Insert year]
  • Mileage: [Insert miles]
  • Crane Hours: [If applicable]
  • Hydraulics: Leak-free and fully operational
  • Tires: Good tread and condition suitable for jobsite use
  • Title: Clean, ready for inspection and use
💰 Pricing & Financing
  • Competitively priced for dual-function value
  • Delivery services nationwide
  • Trade-in accepted
🔧 Why Choose This Dump and Crane Truck?
  • Combines heavy-duty dumping with reliable lifting in one versatile package
  • Saves time and cost by reducing the need for multiple vehicles
  • Trusted crane and truck components for durability and ease of maintenance
  • Ideal for contractors, landscapers, and municipal fleets needing flexible equipment
