Diploma Frame Size Guide How to Choose the Right Frame for Your Diploma
Posted Date: Jun 18th, 2026 at 05:30 PM
0.0 star 62 views
Looking for the right diploma frame size is important when you want to properly display and protect your academic achievement. Since diplomas vary in dimensions across schools and degree levels, there is no universal frame size that fits every document. Most standard diplomas fall around 8.5" x 11", while advanced degrees like doctoral diplomas may require larger frames. Choosing the correct diploma frame size also depends on factors like matting, orientation, and whether you want to include seals or tassels. Measuring your diploma before selecting a frame ensures a better fit and avoids common mistakes. Whether you choose a standard or custom frame, the right size helps create a clean, professional, and long-lasting display of your accomplishment.
