CWS TORQUE TUBE CONCRETE SLAB REMOVAL GRAPPLE Bridge Deck Removal Concrete Pavement Removal Asphalt Removal Demolition 200 to 350 Class Excavators
Posted Date: May 11th, 2026 at 08:40 PM
0.0 star 427 views
Price: $8000.00
CWS TORQUE TUBE CONCRETE SLAB REMOVAL BUCKET / RAKE
Bridge Deck Removal • Concrete Pavement Removal • Asphalt Removal • Heavy Demolition
Fits 200–350 Class Excavators
Price: $8000.00 - NEW COST $16,000.00 4 YEARS AGO PRICE TODAY $20,000.00
Contact ME ABOUT for the Current Pricing / Serious Offers
📍 Location: Cambridge Narrows, New Brunswick, Canada
🚛 Shipping Available Across Canada, USA & International
Condition: New Excellent / Work Ready
From CWS Industries:
The CWS Torque Tube Concrete Slab Removal Bucket/Rake is a specialized, heavy-duty excavator attachment designed to streamline the removal of concrete pavement, bridge decks, and asphalt, specifically engineered for 200 to 350 Class (approximately 40,000–80,000 lb) excavators. It functions by slipping under slabs to lift, break, and load them, significantly increasing productivity over traditional breakers or standard buckets.
Key Features and Benefits
  • Torque Tube Design: Built for high-strength rigidity, the torque tube minimizes torsional flex, ensuring maximum prying and breakout force to snap slabs in half without relying solely on breaking the concrete into small, time-consuming pieces.
  • Slab Management: The bucket/rake design enables the operator to efficiently pick up, lift, and load large sections of concrete directly into dump trucks.
  • Sub-base Protection: The flat-bottom design is optimized to remove concrete slabs without disturbing the sub-base, reducing remediation work and materials.
  • Durability: Constructed with high-tensile, wear-resistant steel (often including 450 Brinell steel or AR400 material) and replaceable teeth/tips.
  • Applications: Ideal for:
    • Bridge deck removal
    • Concrete pavement/driveway removal
    • Asphalt removal
    • Industrial demolition
Typical Specifications (200-350 Class)
  • Bucket Widths: Typically range from 36 to 60 inches.
  • Slab Thickness Capability: Engineered to process slabs ranging from 4 to 22 inches thick.
  • Lugging: Available with direct pin-on or quick-coupler options
Note: Similar tools are often referred to as "Slab Crabs" (Kenco), "Slab Eaters" (Star Industries), or "Concrete Claws" (CID/CMP).
REMOVE CONCRETE SLABS FAST — WITHOUT DESTROYING THE SUBBASE
This custom-built CWS Torque Tube Concrete Slab Removal Bucket was designed for fast removal of:
  • Bridge decks
  • Concrete pavement
  • Highway slabs
  • Asphalt sections
  • Parking lots
  • Industrial concrete pads
  • Heavy demolition projects
  1. Instead of using breakers, loaders, and multiple cleanup crews, this attachment allows one operator to:
  2. Quickly lift and remove pre-cut concrete sections.
  3. Load Grinders or Demolition Trailers
  4. Load Logs or Stumps into trailers or burn piles
  5. Use the teeth and blade to level land and prepare it for planting
  6. Demolish Both Steel and Wood Buildings and so much more.
  7. Note : this works with a hydraulic thumb to load thicker slabs and allows for loading into trucks much better than standard slab buckets which require tilting the buckets which is an issue for dumping the slab.
HOW IT WORKS
Simply:
  1. Saw cut the concrete into manageable sections
  2. Slide the bucket teeth underneath
  3. Tilt upward
  4. Break the slab cleanly at the cut line
  5. Load directly into trucks or stack onsite
This dramatically reduces:
✅ Cleanup costs
✅ Labour requirements
✅ Equipment needs
✅ Damage to underlying sub-base
AGGRESSIVE TORQUE TUBE DESIGN
This unit features:
  • Heavy-duty torque tube construction
  • Reinforced frame design
  • Aggressive teeth for strong slab grip
  • Excellent lifting strength
  • Built for repeated heavy demolition work
Designed to grip and remove heavy slab sections efficiently.
IDEAL FOR
Bridge Contractors
Bridge deck replacement projects
Road Builders
Concrete road removal
Municipal Contractors
Infrastructure replacement
Demolition Contractors
Commercial slab removal
Utility Contractors
Removing concrete for underground access
FITMENT
Fits:
200–350 class excavators
Perfect for machines commonly used in:
  • Highway work
  • Infrastructure demolition
  • Commercial site development
Buyer should verify exact pin fitment.
MAJOR ADVANTAGES
✅ One-man operation
✅ Faster slab removal
✅ Cleaner break points
✅ Reduced debris cleanup
✅ Protects subgrade material
✅ Faster truck loading
✅ Lower operating costs
CONDITION
Excellent NEW condition
Ready to go directly to work
SHIPPING / LOADING
✅ We load your truck
✅ Fast freight quotes available
✅ USA buyers welcome
✅ International shipping available
CONTACT
AllTrac Machinery & Leasing Inc.
Frank Rayner
📞 604-476-7777
📧 [email protected]
🌐 www.alltrac.co
Construction – Model / Part Number concrete slab bucket rake
Construction – Condition New
Construction – Attachment – Pin Size 90 mm or turn to 80 mm
Construction – Attachment – Width 60
Construction – Bucket – Width 59
