ATO Water Chiller
Posted Date: Jun 12th, 2026 at 03:39 PM
0.0 star 207 views
Industrial water chillers serve as critical thermal management equipment to maintain operational uptime in modern manufacturing. By acting as dedicated thermal regulators, these machines continuously remove process heat from industrial machinery and dissipate it through efficient heat exchange systems, preventing equipment overheating and subsequent production downtime.
Air-cooled chillers from the ATO product portfolio offer high-performance, cost-effective cooling solutions across a wide operational range. This equipment line spans from compact 1/2-ton (1750W) units suitable for individual CNC machines, up to heavy-duty 17-ton (60kW) process chillers equipped with 20 HP compressors designed for full assembly lines. Available via direct factory-level sourcing, these cooling systems provide optimized lead times by bypassing extended supply chain delays.
A standard vapor-compression refrigeration cycle drives these chillers to ensure long-term operational reliability. The internal system chills a dedicated stream of liquid coolant and pumps it through a heat exchanger to rapidly lower the temperature of process water, air, or mechanical components. This precise temperature control makes either a centralized liquid-cooled loop or a standalone air-cooled configuration essential across various sectors, including plastics extrusion, surface finishing, electronics manufacturing, liquid processing, cleanroom operations, and food packaging. Consistent operational temperatures delivered by these units directly prevent material warping, reduce scrap rates, and protect high-value capital equipment from thermal stress.
Portable air-cooled industrial chillers provide a practical alternative to traditional setups for facilities seeking to optimize installation costs and long-term maintenance overhead. Operating as self-contained systems, air-cooled scroll chillers eliminate the need for external cooling towers, specialized conditioning additives, or complex municipal infrastructure. An integrated condenser unit featuring specialized finned coils maximizes the heat-dissipation surface area. High-velocity fans force ambient air across these coils to reject heat, with cooling performance scaling based on airflow rates and local dry-bulb temperatures. This closed-loop configuration simplifies deployment, allowing maintenance teams to position the chiller, connect the process lines, and begin operation with minimal setup, while significantly reducing the risks of mineral scaling and system freezing.
Payment Methods Accepted:
Bank Transfer
Credit Card
PayPal
