Advanced Synthetic Lithium Grease PFPEKING PCORR GP for Industrial Bearing Protection Mechanical Systems and EP Lubrication 1KG
Posted Date: Nov 26th, 2026 at 08:46 AM
Price: $200.00
PFPEKING P-CORR GP Advanced Synthetic Lithium Grease is designed for industrial bearing protection and mechanical lubrication applications. Formulated with a synthetic base oil and lithium thickener system, this grease provides reliable lubricating performance for moving components operating under demanding industrial conditions.
Its lubricating film helps reduce friction and wear between metal contact surfaces, supporting smooth mechanical movement and helping protect bearings and related components during continuous operation. The grease is suitable for evaluating in industrial bearings, rotating equipment, mechanical assemblies, and general-purpose EP lubrication applications where consistent lubrication and component protection are required.
With its versatile formulation, PFPEKING P-CORR GP can be considered for various industrial maintenance requirements, helping support equipment reliability, reduce maintenance frequency, and extend the service life of lubricated components.
