24VAC WiFi Smart Thermostat Manufacturer OEMODM Supplier OWON
Posted Date: Nov 28th, 2026 at 04:26 PM
Looking for a reliable smart thermostat manufacturer or wholesale supplier for your HVAC business?
OWON Technology is an ISO 9001:2015-certified IoT device manufacturer specializing in 24VAC WiFi smart thermostats, offering OEM/ODM customization, wholesale supply and technical integration support for international business partners.
Our smart thermostats are designed for conventional HVAC systems, heat pumps, dual fuel systems and residential heating and cooling applications.
Key Features
24VAC HVAC system compatibility
Up to 2H/2C conventional and 4H/2C heat pump control, depending on model
Dual fuel system support
Auxiliary and emergency heat control
WiFi remote control and programmable schedules
Wireless remote temperature sensor options
Occupancy and humidity sensing on selected models
Guided installation and system configuration
Featured Smart Thermostats
PCT5231 – WiFi Smart Thermostat with Remote Sensors
Supports up to 10 remote sensors for multi-room temperature monitoring, with flexible HVAC configuration and Bluetooth-assisted setup.
PCT533 – Advanced WiFi Smart Thermostat
Features built-in occupancy and humidity sensing, touchscreen operation and advanced HVAC control for residential comfort management.
Who We Serve
HVAC contractors and heat pump installers
HVAC equipment wholesalers and distributors
Smart home dealers and system integrators
Apartment and multifamily housing solution providers
HVAC brands seeking OEM/ODM manufacturing partners
OEM/ODM & Wholesale Opportunities
OWON provides product customization, sample evaluation, wholesale supply and technical support for smart HVAC projects worldwide.
Explore our WiFi Thermostat Solutions for product specifications, HVAC compatibility and model selection.
Contact OWON Technology for samples, wholesale quotations, distribution opportunities and OEM/ODM cooperation.
Email: [email protected]
| Payment Methods Accepted: |
Bank Transfer
Credit Card
PayPal
| Condition | New |
| Contact Person | David |
| Website | https://www.owon-smart.com/ |
| Business / Supplier Name | OWON Technology |
| [email protected] | |
| Unit Type | Pieces |
| Bulk Discount Available | Yes |
