2025 SANY SY95C Midi Excavator – Power Meets Precision
Posted Date: Jul 20th, 2025 at 04:47 AM
0.0 star 226 views
🚜 2025 SANY SY95C Midi Excavator – Power Meets Precision
✅ Tier 4 Final | 💥 High Performance | ⚙️ 5-Year Warranty
🔧 Machine Specifications
  • Make/Model: 2025 SANY SY95C
  • Operating Weight: Approx. 20,238 lbs (9.2 tons)
  • Engine: Yanmar 4TNV98C – Tier 4 Final
  • Horsepower: 72 HP
  • Max Digging Depth: 14 ft 3 in
  • Max Reach: 24 ft 6 in
  • Bucket Capacity: 0.37 yd³ (standard)
🏗️ Performance & Power
  • Smooth, responsive hydraulic system built for productivity
  • High digging forces and fast cycle times for heavy-duty applications
  • Two-speed travel and excellent ground clearance for mobility across terrains
  • Advanced load-sensing hydraulics improve fuel efficiency and control
  • Mid-size footprint allows it to work in tight areas while handling larger tasks
💡 Features & Benefits
  • Zero tail swing design – perfect for urban or confined worksites
  • Deluxe ROPS/FOPS cab with A/C, heat, and high-visibility windows
  • 7” touchscreen monitor with diagnostics and customizable settings
  • Standard auxiliary hydraulics – plug-and-play for thumbs, breakers, augers, etc.
  • Reinforced boom & arm with extended-life components for heavy lifting
🛠️ Operator Comfort & Service
  • Adjustable suspension seat and ergonomic joystick controls
  • Excellent visibility for safer operation
  • Easy-open side panels and grouped service points for quick maintenance
  • Rearview camera and LED lighting package for increased jobsite safety
💰 Why Choose the SY95C?
  • Backed by SANY’s industry-leading 5-Year/5,000-Hour Warranty
  • Perfect for contractors needing more muscle than a mini, without the size of a full excavator
  • Financing & delivery available — ask about 2025 launch specials and rebate programs!
  • Built to handle trenching, utility work, site prep, demolition, and more
📞 Contact us today to schedule a demo or get a quote.
Your next-level excavation partner is ready to work.
