2019 John Deere 470G LC Excavator – Heavy-Duty Power & Precision
Posted Date: Jul 13th, 2025 at 04:25 AM
0.0 star 142 views
Price: $215000.00
🚧 2019 John Deere 470G LC Excavator – Heavy-Duty Power & Precision
Top-Tier Performance | Tier 4 Final Engine | Built for Maximum Productivity
🔧 Machine Overview – John Deere 470G LC
  • Make/Model: John Deere 470G LC
  • Year: 2019
  • Operating Weight: Approx. 112,000 lbs (50,802 kg)
  • Engine: John Deere PowerTech™ PSS 13.5L – Tier 4 Final Emissions Compliant
  • Horsepower: 367 HP (274 kW)
  • Max Dig Depth: Approx. 27 ft 11 in (8.5 m)
  • Max Reach at Ground Level: Over 42 ft 7 in (13 m)
  • Bucket Capacity: Up to 4.1 cu. yd. (depending on configuration)
  • Undercarriage: Long Carriage (LC) for enhanced stability and lift capacity
🛠️ Performance & Hydraulic Features
  • Hydraulic System:
    • Load-sensing hydraulics with optimized pump flow for smooth, efficient operation
    • Boom priority and simultaneous multi-function capabilities
    • Factory auxiliary hydraulics for attachments such as thumbs, breakers, and grapples
  • Engine & Efficiency:
    • Tier 4 Final engine with advanced emission controls (EGR, DOC, SCR, DPF)
    • Auto-idle and economy modes to reduce fuel consumption
    • Cooling-on-demand system to optimize engine temperature and performance
👨‍💻 Operator Station
  • Cab:
    • Spacious, pressurized cab with ROPS certification
    • Climate control with heat and air conditioning
    • Wide, clear visibility and noise reduction features
  • Controls & Technology:
    • Ergonomic joystick controls with customizable settings
    • 7-inch color touchscreen display for machine diagnostics and settings
    • Telematics-ready with JDLink™ for remote monitoring and fleet management
✅ Ideal Applications
  • Mass excavation and heavy earthmoving
  • Large-scale commercial construction
  • Demolition and material handling
  • Quarry and aggregate loading
  • Pipeline and infrastructure projects
🔍 Condition & Inclusions
  • Condition: Excellent, well-maintained, jobsite ready
  • Undercarriage: [Insert wear % or recent servicing details]
  • Includes:
    • Heavy-duty digging bucket
    • Quick coupler (if applicable)
    • Auxiliary hydraulic lines
  • Title: Clean and transferable
💰 Pricing & Financing
  • Competitively priced for a machine of this size and performance
  • Delivery available nationwide
  • Trade-ins accepted
🔧 Why Choose the 2019 John Deere 470G LC?
  • Powerful and fuel-efficient engine designed for heavy workloads
  • Advanced hydraulics for precise and productive digging
  • Operator comfort and advanced technology improve efficiency and reduce fatigue
  • Strong resale value and wide dealer support network
