2019 John Deere 35G Mini Excavator – Compact Power, Built to Perform
Posted Date: Jul 20th, 2025 at 04:48 AM
0.0 star 194 views
Price: $67500.00
🟢 2019 John Deere 35G Mini Excavator – Compact Power, Built to Perform
🔧 Machine Specs:
  • Model Year: 2019
  • Make/Model: John Deere 35G
  • Operating Weight: ~7,760 lbs
  • Engine: Yanmar 3TNV88 – Tier 4 Final
  • Horsepower: 23.3 HP
  • Max Dig Depth: Approx. 10 ft
  • Max Reach: Approx. 17 ft
  • Bucket Capacity: Varies (standard trenching bucket installed)
💪 Performance Highlights:
  • Zero Tail Swing Design – maneuver easily in tight spaces without sacrificing power
  • Smooth, responsive hydraulics for efficient digging and lifting
  • Two-speed travel for quick jobsite repositioning
  • Extended undercarriage for greater stability and lift capacity
  • Ideal for landscaping, utility work, residential construction, and light demolition
🛠️ Operator Comfort & Features:
  • Open ROPS or Enclosed Cab options (depending on model setup)
  • Easy-to-use pilot controls with low effort and high precision
  • Adjustable suspension seat for all-day comfort
  • Ergonomic layout with excellent visibility
  • Hydraulic thumb and quick coupler (optional attachments available)
🔍 Why Buy This Machine?
  • Low-hour, well-maintained unit – ready to work
  • Fuel-efficient and emission-compliant
  • Simple serviceability with ground-level access
  • John Deere reliability backed by strong parts & dealer support
  • Financing available — ask about delivery and extended warranty options!
📦 Ideal for: Contractors, municipalities, rental fleets, and property owners
📍 Call or message now to schedule a viewing or secure delivery
