2016 John Deere 470G LC Excavator – High-Capacity, Built for Production
Posted Date: Jul 10th, 2025 at 11:17 PM
0.0 star 249 views
Price: $175000.00
🚧 2016 John Deere 470G LC Excavator – High-Capacity, Built for Production
Massive Digging Power | Rugged Durability | Designed for Serious Earthmoving
🔧 Machine Overview – John Deere 470G LC
  • Model: 470G LC
  • Year: 2016
  • Operating Weight: Approx. 112,916 lbs (51,210 kg)
  • Engine: John Deere PowerTech™ 13.5L Tier 4 Final diesel engine
  • Horsepower: 367 HP @ 1,900 RPM
  • Max Dig Depth: Over 27 ft
  • Max Reach: Approx. 40 ft at ground level
  • Bucket Capacity: Typically 2.0 to 4.75 cubic yards (depending on bucket)
  • Undercarriage: Heavy-duty with wide steel tracks for stability and traction
🛠️ Performance & Hydraulics
  • Hydraulic System:
    • Closed-center, load-sensing hydraulics for responsive operation
    • Multi-functioning capability — smooth operation of boom, arm, and bucket
  • Cooling System: Auto reversing fan for cooling efficiency and reduced clogging
  • Fuel Efficiency: Auto idle and power modes to reduce fuel usage without sacrificing performance
  • Lift Capacity: Excellent lifting capability at full reach for pipe, rock, and demolition tasks
👨‍💻 Operator Comfort & Control
  • Cab Features:
    • Pressurized, climate-controlled cab with wide visibility
    • Air-suspension heated seat and adjustable ergonomic controls
  • Technology:
    • Onboard diagnostics via LCD monitor
    • JDLink™ telematics enabled for remote machine monitoring
    • Optional grade control and laser-ready systems
✅ Ideal Applications
  • Mass excavation and site prep
  • Deep trenching and foundation digging
  • Heavy demolition and rock work
  • Commercial construction projects
  • Municipal and utility infrastructure work
🔍 Condition & Extras
  • Hydraulics: Leak-free, strong, and well-maintained
  • Undercarriage: [Insert percentage or condition – e.g., 80%]
  • Bucket: Standard heavy-duty digging bucket included (other attachments optional)
  • Maintenance: Regularly serviced, fleet maintained
  • Title: Clean and ready to transfer
💰 Pricing & Financing
  • Competitively priced for its class and condition
  • Delivery and transport assistance available
  • Trade-ins considered
🔧 Why Choose the 2016 John Deere 470G LC?
  • Massive size and power for high-output operations
  • Industry-trusted brand with strong support and resale value
  • Operator-friendly cab with advanced controls and comfort
  • Smart hydraulics and fuel efficiency help lower cost per hour
  • Built for contractors who demand performance, reliability, and efficiency
