Menu
Quick Eze Links
Werk-Brau 24-36-48 INCH 200-240 EXTREME DUTY DIGGING EXTREME DUTY AMERICA-MADE AR400 AND T-1 STEEL200-240 CLASS EXCAVATOR BUCKETS
Posted Date: May 7th, 2023 at 03:21 PM
0.0 star
Price: 5000.00 Negotiable
EXTREME DUTY AMERICA-MADE T-1 STEEL BUCKETS CONSIST OF THE FOLLOWING :
1) 24-INCH PIN OR PIN GRABBER 3 TOOTH BUCKET C/W 80MM PINS 12.25 INCHES BETWEEN EAR - $5000.00
2) 36-INCH PIN OR PIN GRABBER 5 TOOTH BUCKET C/W 80MM PINS 12.25 INCHES BETWEEN EAR - $6000.00
3) 48-INCH PIN OR PIN GRABBER 6 TOOTH BUCKET C/W 80MM PINS 12.25 INCHES BETWEEN EAR - $6000.00
THESE BUCKETS ARE WORTH $8000.00 - 10,000.00 USD EACH
TAKE THE SET OF 3 BUCKETS FOR $15,000.00 CDN AND OR WILL SEPARATE AS PRICED ABOVE ONCE BUCKETS ARE GONE
ALL BUCKETS ARE IN PERFECT SHAPE COMPLETE WITH PINS AND HAVE BEEN HARD-SURFACED - READY TO WORK
HIGH-QUALITY AMERICAN-BUILT T-1 STEEL BUCKETS THAT CAME FROM OUR LOW HOUR (5000 HOUR)) LINKBELT 235 X3 THAT THE BUYER WANTED A WEDGE TO MATCH HIS OTHER MACHINES??
THIS WILL FIT ALL 160-240 CLASS EXCAVATORS INCLUDING KOMATSU 200-210-228-238-308 ETC
ALL ARE LOCATED IN OUR YARD IN LANGLEY BC
FINAL CLEARING OUT YARD OF EXCAVATING - DEMOLITION ATTACHMENTS - CLICK MY WEBSITE OR MY OTHER LISTINGS FOR MORE DETAILS OR EMAIL ME TO GET A COMPLETE UPDATED LIST OF OVER 100 ITEMS
THIS GIVES YOU A COMPLETE SET OF BUCKETS NOW
NOT HAVE TO WAIT MANY WEEKS TO BUILD OR DELIVER
Available for Werk-Brau manufactures all attachments to O.E.M. specs for all makes and models of excavators.
Recommended Applications
Werk-Brau's severe-duty buckets are specifically designed with an aggressive dig angle to effectively excavate in the toughest conditions. Ideal applications for this bucket include but are not limited to demolition work, shot rock, high abrasive applications, and moderate prying. When paired with a thumb, this bucket can also be used for material handling. Construction
T-1 steel is utilized in all critical or high wear components. This bucket features tapered side plates, horizontal wear straps, and an extra thick cutting edge is backed by a wear plate that covers the entire bucket bottom. Side wear plates protect the bucket sides in the high wear areas and extend the buckets operation life. The tip radius on the severe-duty excavator bucket is to or within O.E.M. specifications. Each bucket is engineered with tapered side plates to reduce wear on the sides of the bucket, and to allow for easier dumping. the cutter bit is made from heavy-duty cast material. Cutting Equipment Options
Equipped with industry-standard teeth for extra durability. In most cases, the tooth size is increased to tolerate the more severe digging application. A selection of quality brand teeth are available to choose from. Box rippers available and installed upon request. Standard Sizes
3/8 cubic yds. to 4 cubic yds. of various widths are available. Special designs and capacities are available upon request.
Additional Features
Bolt-on side cutters are highly recommended for added endurance. Box rippers are available and can be installed upon request. Special designs and capacities are available, please request a quote from a Dealer or contact Werk-Brau directly.
