TEREX WS-120MD 160 HYD HP DUAL DRUM GRINDER 30-50 TON EXCAVATOR
Sep 29th, 2023 at 22:12 Construction / Logging Langley 271 views Reference: 223Location: Langley
Price: $40,000 Negotiable
THIS IS SET UP FOR OUR LONG REACH PC450LC-8 KOMATSU BUT WILL FIT ANY MACHINE WITH 100 MM PINS WITH 14.75 INCHES BETWEEN THE EARS OR BUSH DOWN TO 90 MM PINS - FITS AS IS THE FOLLOWING MACHINES:
KOMATSU PC 400 - PC450
KOBELCO SK450 - SK485
HYUNDAI R420LC - R450LC-3
CAT 324D - 325D - CAT 330 - 330D
WILL FIT MOST 300-450 MAHCINES WITH GEITH COUPLERS THAT GRAB 90 - 100 MM PINS AND OTHER GOOD COUPLERS
BUT TOP PLATE CAN BE MODIFIED TO FIT ANY 250 - 500 CLASS EXCAVATOR
MOUNTED AS A THIRD MEMBER ON LARGER MACHINES (30-50 TON CLASS) AS A THIRD MEMBER MOUNTING SYSTEM IS WORTH OVER $150,000.00 TO REPLACE
ALSO HAS PRESSURISED WATER MISTING SYSTEM FOR DUST REDUCTION - JUST HOOK UP PRESSURIZED WATER TO THE WATER LINES
SEE A PDF FILE ON THE GRINDERS - (copy and paste)
SEE VIDEOS OF THE GRINDER (copy and paste)
https://youtu.be/rSleaL-FoCo
https://youtu.be/BdzFNabFKQ4
DRUM CUTTER SPECIFICATIONS:
Hydraulic input power HP 160
Oil fl ow rate required gpm 66 - 106
Cutting head width in 47.2
Weight, approx. lbs 4500 LBS FOR BARE GRINDER WITH EXCAVATOR 100 PINS MOUNTING BRACKET
Recommended excavator weight lbs
THIRD MEMBER MOUNTING 66,000 - 100,000 PLUS
Basic model incl. milling head
Special equipment
Transverse cutter head Longitudinal cutter head Rock cutting drum Demolition cutting drum Scaling cutting drum
FIELDS OF APPLICATION
CANAL AND PIPELINE CONSTRUCTION LANDSCAPE GARDENING BIOREMEDIATION/SOIL MIXTURE QUARRYING SENSITIVE AREAS ROAD CONSTRUCTION TUNNELLING AND MINING BUILDING RENOVATION AND DEMOLITION
TEREX’ mission is to make innovative products. For over 40 years the TEREX Group has been manufacturing roadheading machines with cutting heads for mining and tunnelling operations.
In the field of hydraulic transverse cutting units, TEREX is the world-wide market leader and epitomises cutting-edge tech- nology made in Germany.
From civil engineering to landscape gardening – TEREX‘ cutting units show their strength and flexibility in a multitude of appli- cations. Various hydraulic motors and cutting heads can be attached to TEREX | Schaeff cutting units, enabling an optimum adjustment to operate conditions.
The product range comprises seven types of transverse cutting units with hydraulic drive powers of 30 HP, 40 HP, 60 HP, 80 HP, 120 HP, 160 HP and 200 HP respectively.
TEREX also offers solutions for special applications, such as cutting drums and slot cutting drums in various widths and diameters, drums for cutting tree stumps, and anti-dust systems for indoor operations. Behind TEREX’ products you will find a network of distributors who know the business inside out. Local dedicated service and support teams offer customers professional support before, during and long after the sale.
INNOVATIVE ENGINEERING – INDIVIDUAL SOLUTONS – COMMITTED CUSTOMER SERVICE OFFERING 1) Extremely economic 2) Extremely accurate cut 3) Low vibration FOR SENSITVE 4) Low noise 5) Suitable for underwater operations 6) Low maintenance 7) Suitable for narrow and deep trenches 8) Recycling of excavated material ADVANTAGES OF CUTTING TECHNOLOGY HYDRAULIC TRANSVERSE CUTTING UNITS TRUE ALLROUNDERS
THIS GRINDER IS FOR:
Medium-hard to hard rock and concrete
Wear-protected spiral blade for limited pick penetration, lower vibration and smoother operation
BUT DUE TO THE SMOG AND TRAFFIC IN THE FRASER VALLEY, WE ARE LEAVING BC FOR NB WHERE WE BOUGHT A NEW HOME.
THIS UNITS MOUNTED ON A 250-500 CLASS EXCAVATOR WOULD RENT OUT FOR $400.00 PLUS PER HOUR
We can supply trucking anywhere in North America Except Mexico - we get great rates
