KOMATSU PC450-LC8 LONG REACH - HYDRARAM 175 HYDRAULIC HP SHEET PILE - H PILE DRIVER - DEMOLITION - LONG REACH EXCAVATOR
Oct 19th, 2023 at 20:00 Industrial - Machinery Canada 227 views Reference: 268Location: Canada
Price: $400,000 Negotiable
Custom-Built Excavator for Diverse Operations – Take Machine With 1 Bucket for $400,000
Or With The New2021 Hydra-Ram 175 Hydraulic HP Hydraram Sheet Pile Driver for $500,000
Excavator Specifics
This innovative excavator is a game-changer because it is made to precisely perform a variety of tasks.
With no expense spared, a thorough rebuild was carried out, culminating in a fully improved machine completed in 2023.
Rebuilding would have cost well over $1,300,000 if the HydraRam Sheet Pile Driver hadn't been used.
7,300 hours on excavating (total rebuild in 2023 0 hours since then)
Factory Komatsu 3-Piece Boom with Various Adaptable Attachments
Improved for Excavation, Demolition, Sheet Pile Driving, and Additional Uses - includes a brand-new, $250,000-worth New 2021 175 Hydraulic HP Hydraram Sheet Pile Driver for $500,000
Our entire investment, including the HydraRam Sheet Pile Driver, was over $600,000 or $800,000.
In addition to the New Hensley 46-Inch Extreme Duty Digger Bucket
Competencies:
Excavation to a depth of 34–36 feet is possible, and two bucket sizes—46 inches for 2.5 yards and 70 inches for 4 yards—are available (both are Hensley Extreme Duty).
Pile Driving Sheets
Large Hydraulic Hammers and Processors for Demolition Demolition hydraulic grippers (horizontal and vertical reach: 60–70 feet depending on attachment)
Big Two-Drum Grinder
Extra Tools Are Available:
Kishoffer T40HPX-114 Helix Drive Grapple, 2.5 Yard Capacity, 20,000 Lb (Est. Value: $85,000)
Selecting From Several Buckets
2020 - 0 Hours Since Factory Rebuilt Okada Cut82 Rotating Demolition Shear Hammer model: ORV7500, 7500 foot pounds Number of Serial: 363B538 Measurements: 124" L 5,950 lbs. of operating weight—and much more!
Reasons to Select This Excavator:
Easily Manages Different Attachments Personalized 3-Piece Boom for Accurate Tasks
Can Replace Cranes for Sheet Pile Work in Tight Places; Rebuilt and Improved for Exceptional Performance
A Flexible and Effective Supplement to Any Fleet
Will Consider A 1964–1971, Classic Muscle Car, Or A 35–40 Foot Newer Class A Diesel Pusher Motorhome As Part Trade
Funding Accessible AOC
Frank's number is 604-476-7777.
The place is Langley, BC
Note: We are selling this outstanding piece of equipment because, after 53 years in the demolition and rock excavation business, we are retiring and moving due to health issues.
A UNIQUE 60-FOOT REACH 3-PIECE BOOM FOR SHEET PILE DRIVING - LARGE DUAL DRUM GRINDERS, GRAPPLE BUCKETS, DEMOLITION PROCESSORS, LARGE HAMMERS, ETC.
A NEW KOMATSU CUSTOM 60 FOOT EXTREME DUTY 3 SECTION BOOM is included in this low-hour, mint-condition machine, which is worth over $300,000 when installation costs are included.
can drive 40, 50, or 60 feet in sheets and replace large crane-mounted units with Powerpak hydraulic units. It also reduces the number of workers from four or five to two and can drive four times in an hour. Additionally, it is ready to drive piles half an hour after arriving on site, unlike cranes, and it can operate in tight spaces and on swamp ground, using wood pads only when necessary.
USE A SINGLE MACHINE TO MANAGE LARGE 12000 ft lb HYDRAULIC HAMMERS, GRAPPLES, HYDRAULIC DUAL DRUM BRINDERS, PLATE COMPACTORS, AND VARIOUS BUCKETS.
2021 HYDRARAM SHEET PILE DRIVER WITH 175 HYDRAULIC HORSEPOWER TO DRIVE SHEET PILE - H PILES ETC.
WHAT THE MACHINE HAS IS AS FOLLOWS:
ALL-NEW CUSTOM HYDRAULIC STEEL LINES - VALVES - FOR 3 HYDRAULIC FUNCTIONS PLUS CASE DRAIN, CUSTOM MODIFIED NEW FACTORY KOMATSU 3-PIECE BOOM C/W
A brand-new, expertly installed auto greaser system
CHANGE ATTACHMENTS FROM THE SEAT IN MINUTES WITH THE NEW GEITH HYDRAULIC PIN GRABBER COUPLER
KOMATSU DEMOLITION COUNTERWEIGHT HYDRAULIC REMOVABLE ($50,000.00 Factory Option)
CASE DRAIN LINE AND CUSTOM HYDRAULICS FOR THREE AUXILIARY HYDRAULIC CIRCUITS TO RUN ANY DEMOLITION OR SHEET PILE ATTACHMENT
AT A HEIGHT OF 14 FEET ON THE BED, IT IS COMPLETELY MOVABLE ON AN 8 OR 9 AXLE LOW BED.
In order to obtain the necessary height and reach configuration that isn't achievable with a standard excavator boom:
CHARLIE SMITH MACHINE REMOVED THE EXISTING EXCAVATOR BOOM AND INSTALLED A BRAND NEW KOMATSU LOG LOADER BOOM C/W NEW HYDRAULIC CYLINDERS - REMOVED THE GRAPPLE AND CUSTOM INSTALLED THE ORIGINAL STICK - REBUSHED THE ENTIRE STICK COMPLETELY REBUILT BOTH BUCKET - STICK CYLINDERS - REBUILT THE GEITH HYDRAULIC PIN GRABBER COUPLER
DC WELDING LANGLEY INSTALLED ADDITIONAL CUSTOM QUICK DETACH COUNTERWEIGHT'S THAT FIT BEHIND AND CAN BE REMOVED WITH THE FACTORY HYDRAULIC DROP COUNTERWEIGHT A VALUE OF OVER $35,000.00
MACHINE HAS NEW O HOUR KOMATSU HYDRAULIC PUMPS INSTALLED
SMS KOMATSU SURREY WENT THROUGH AND REBUILT THE COMPLETE HYDRAULIC SYSTEM INCLUDING THE MAIN VALVE BODY TO INSTALL THE ADDITIONAL HYDRAULIC VALVES AND SET UP TO RUN THE NEW HYDRARAM SHEET PILE DRIVER OR ANY DEMOLTION ATTACHMENTS FOR A COST OF OVER $75,000.00
NAHANNI TRUCK AND TRAILER BLASTED THE UNDERCARRIAGE AND ALL GUARDING WAS REMOVED AND BLASTED AND MAIN BODY WAS HAND SANDED THEN COMPLETELY PAINTED WITH QUALITY EPOXY PAINT AND NEW KOMATSU DECALS INSTALLED ON THE MACHINE
SET UP FOR DEMOLITION PROCESSORS - HAMMERS - GRAPPLE BUCKETS - LARGE HOE-PAKS - DIGGING BUCKETS ETC.
ALL OF WHICH ARE AVAILABLE FOR THIS MACHINE TO WORK NOW.
MACHINE COST TO REPLACE WELL OVER 1.3 MILLION AND WITH TODAY'S ISSUES MORE THAN 6 - 12 MONTHS OF PARTS AND WORK. TO BUILD
https://youtu.be/zIcTctyhjlI
