Menu
Quick Eze Links
KOMATSU PC308USLC-3EO ZERO SWING & PC450LC-8 CUSTOM LONG REACH EXCAVATORS & 30+ ATTACHMENTS
Posted Date: Dec 11th, 2023 at 12:16 PM
0.0 star
Price: 125000.00 Negotiable
LIQUIDATING THESE READY TO WORK FLAWLESS CONDITION MACHINES WHICH ARE :
1)  2012 Komatsu PC308USLC-3EO 2.5 YARD EXCAVATOR FOR $125,000.00
2) CUSTOM PC450LC-8 EXCAVATOR $1.300.000 LONG REACH PILE DRIVER - DEMOLITION EXCAVATOR FOR $400,000.00
3) OVER 50 ATTACHMENTS FOR THESE MACHINES AT BLOWOUT PRICING AS WE ARE MOVING FROM BC TO NB AND WILL BE CHANGING DIRECTION.
NOTE: PC450LC-8 IS AT MD TRANSPORT YARD TEMISKAMING SHORES ONTARIO P0J 1K0 - THE PC308USLC-3E0 IS AT OUR YARD CAMBRIDGE NARROWS NB - JUST LOWERED THE PRICE ON THESE  UNITS TO MOVE THIS EQUIPMENT QUICKLY - FRANK 604-476-7777 or TOLL FREE Phone : 1-(833) 693-9323
SEE MORE AND COMPLETE DETAILS IN MY OTHER ADS OR SEE MORE INFORMATION FOR THESE MACHINES BELOW:
1) 2012 KOMATSU  PC308USLC-3EO 2.5 YARD EXCAVATOR & 18 ATTACHMENTS
TRUE RARE ZERO TAIL SWING PLUS 16 HIGH QUALITY ATTACHMENTS FOR THIS HARD TO FIND 73,000 LB EXCAVATOR  IN THIS CONDITION - NO DEF - NO SENSOR OR EMISSIONS ISSUES
This machine is in excellent physical condition with its original paint and no dents nor body work required.
It comes from a large fleet that was liquidated due to the owner's death.
The machine has obviously not been a demolition or hard digging machine and with the complete additional lifting valves and Isogarde swing limiter options installed and the perfect cab and how tight the machine is it appears to have been used more for a tracked excavator jobsite crane
The machine has been fully maintained by SMS through a regular scheduled maintenance program.
It is located in Cambridge Narrows NB and will be ready to work immediately.
It does not require any additional time or maintenance before it can be put to use.
THIS MACHINE HAS O HOURS ON COMPLETE SERVICE AND WAS GONE THROUGH TO MAKE IT PERFECT - READY TO WORK NOW
UNDERCARRIAGE IS 90% - NO LEAKS AND ALL PINS ARE TIGHT - MOTOR AND HYDRAULICS ARE PERFECT
TAKE THIS EXCELLENT READY TO WORK 73,000 LB MACHINE WITH AS NEW EXTREME DUTY ESCO 34 INCH TRENCHING BUCKET FOR $125,000.00.
NEW COST TO REPLACE IS OVER $500,000.00 SO TAKE THIS MACHINE FOR 1/4 OF THAT PRICE AND HAVE WORKING NOW NOT MONTHS FROM NOW.
FINANCING AVAILABLE ****OAC*****
THIS CAN BE MOVED QUICKLY BY OUR TRUCKER - WE GET GREAT RATES.
COMPLETE 0 HOURS SINCE THE FOLLOWING SERVICE:
1) ALL OILS AND FILTERS CHANGED INCLUDING FINAL DRIVES
2) 2 NEW HD BATTERIES AND BATTERY CUT-OFF SWITCH INSTALLED
3) TRACKS TENSIONS ADJUSTED
4) GO OVER MACHINE FOR ANY ISSUES AND REPAIRED
5) REMOVED THE 80MM HYDRAULIC  PIN GRABBER COUPLER AND PUT ON AS NEW ESCO HARD SURFACED AND BUILT FOR PC308 KOMATSU 34 INCH EXTREME DUTY TRENCHING BUCKET WITH AS NEW PINS - NO WEAR IN STICK OR H LINK BUSHINGS AND BUCKET IS TIGHT
MACHINE ALSO COMES WITH THE ORIGINAL 44 INCH 5 TOOTH BUCKET SEEN IN THE PICTURES - BUT IT DOES REQUIRE A DAYS WORTH OF WORK PLATING AND HARD SURFACING TO MAKE PERFECT AND AS NEW
THE 80MM HYDRAULIC PIN GRABBER COUPLER IN THE PICTURE IS ALSO WITH IT THE PIN BORES ARE PERFECT BUT IT NEEDS THE CYLINDER REBUILT BUT AS WE WERE GOING TO PUT ON THE FOLLOWING WE JUST REMOVED IT??
NOTE: DO HAVE A NEW TAKE OFF GEITH 90 MM PIN GRABBER COUPLER THAT WE WERE GOING TO INSTALL TO GRAB LARGER BUCKETS AND MANY OF THE FOLLOWING ATTACHMENTS
THAT COULD BE AVAILABLE IF WANTED AT 1/2 NEW COST FOR $8000,00 C/W NEW PINS - MACHINE OF COURSE IS PLUMBED AND CONTROLS ARE INSTALLED TO RUN IT
The machine being offered is a Komatsu PC308USLC Hydraulic Excavator. It is designed with a short tail swing profile, specifically for working in congested or confined areas.
This reduces the risk of safety issues that conventional excavators might pose.
It is perfect for projects on roadways, bridges, urban areas, or any location with limited space.
The PC308USLC provides the expected performance and productivity of Komatsu equipment.
THIS MACHINE HAS $35,000.00 OF THE FOLLOWING OPTION INSTALLED:
1) ISOGARD COMPUTER SWING LIMITER TO STOP MACHINE SWINGING INTO POWER LINES OR OTHER OBSTACLES
To help operators of cranes and excavators work safely next to power lines or other obstacles.
Model 610 for excavators can be programmed to limit in many combinations of angle and swing. The programming is done in a very simple 2-step procedure.
Includes
Keyboard
Inclinometer
Swing detector
2) LIFTING VALVES - SO LEGALLY CAN BE USED AS A CRANE - BOOM AND STICK WILL NOT CREEP OR LOWER UPON HOSE FAILURES
Burst protection is to be fitted on all earthmoving equipment used as a crane, where the rated capacity exceeds 1 tonne. The burst protection is to be fitted to both the boom and dipper arm of the equipment. Burst protection is to comply with the performance requirements of ISO 8643: Earthmoving machinery – Hydraulic excavator and backhoe loader boom-lowering control device – Requirements and tests as per WorkSafe.
Copy and paste the Komatsu PC308USLC PDF feature sheet:
https://www.mediafire.com/file_premium/2epvsismwtfnxl1/KOMATSU-PC308USLC-FACTORY-BROCHURE.pdf/file
Some key features of the Komatsu PC308USLC include:
Small occupied width: The machine occupies a width of 5325 mm (17'5") or less, allowing it to work efficiently in confined areas. The tail swing protrudes only 1.5" from the tracks.
High stability: It offers exceptional lifting capacity and stability, thanks to its large counterweight that requires no additional clearance.
Larger cab: The Komatsu PC308USLC has a spacious cab with a low-noise design and viscous cab mounting. The sliding convex door makes it easy to enter confined areas and reduces the risk of damage when open on roadways.
Standard features of the machine include effortless joystick controls, a large seat, cup holder, sliding window, internal storage with a hot and cold box, and auto air conditioning.
ONLY MACHINE LIKE IT IN NORTH AMERICA TOOK 2 YEARS TO PUT TOGETHER TOTALLY REBUILT MACHINE FINISHED IN 2023 LOOKS AND OPERATES AS NEW WITH NO EMMISIONS ISSUES NOR DEF - SENSOR ISSUES
THIS IS NOT A SPAGETTI BOOM  LONG REACH - USE LARGE 12000 ft lb HYDRAULIC HAMMERS - 10,000 LB HYDRAULIC DEMOLITION PROCESSORS - GRAPPLES - HYDRAULIC DUAL DRUM GRINDERS - PLATE COMPACTORS - DIG WITH VARIOUS BUCKETS UP TO 4 YARDS ALL WITH ONE MACHINE
HYDRAULIC REMOVEABLE KOMATSU DEMOLITION COUNTERWEIGHT  ($50,000.00 Factory Option) PLUS $35,000.00 IN ADDITIONAL CUSTOM REAR TOP MOUNTED WEIGHTS  THAT IS DESIGNED TO GO AROUND THE FACTORY HYDRAULIC DROP SYSTEM - KEEPS REAR SWING CLEARANCE TO FACTORY SPECS OF 1.320 METERS OR 52 INCHES SO AS TO SWING OVER SHEET PILES WITH A 42 INCH WCB REQUIRED ABOVE GROUND HEIGHT WHILE DOING THE EXCAVATION SWINGING OVER  THE SHEET PILES
CAN BE MOVED COMPLETE ON 8 or 9 AXLE LOW BED AT HEIGHT OF 14' 2 FEET ON THE BED FOR LOCAL MOVES OR 13' 8 INCHES AS SEEN IN PICTURE #3 ON THE 10 AXLE
****NOTE****: NOTE:  MACHINE IS AT MD TRANSPORT YARD TEMISKAMING SHORES ON P0J CAN HAVE ON THE MD TRANSPORT TRUCK IN PICTURE 4  AS SEEN IN ONE PIECE ANYWHERE IN  EASTERN CANADA OR EASTERN USA
WE MOVED MACHINE THERE BEFORE THE SNOW HIT IN BC TO AVOID THE MOUNTAINS PASSES
JUST LOWERED THE PRICE ON THESE UNIT TO MOVE THIS EQUIPMENT QUICKLY - FRANK 604-476-7777 or TOLL FREE Phone : 1-(833) 693-9323 -
WE ALSO HAVE SITTING THERE AVAILABLE FOR PURCHASE WITH EITHER  MACHINE OR SOLD SEPARATELY:  (SEE MY OTHER AD FOR THESE ATTACHMENTS)
1) OTHER BUCKETS INCLUDING A NEW X HAND 60 INCH 6 IN 1 CLEANUP - GRAPPLE - SCREENING BUCKET WORTH $60,000.00 TAKE IT FOR $25,000.00
2) A MB BF90 CONCRETE AND ROCK CRUSHER BUCKET C/W CORRECT TOP PLATE MOUNT FOR THIS MACHINE WORTH $90,000.00 NEW TAKE IT FOR $35.000.00
3) AS NEW SLASHBUSTER STUMP GRINDER C/W CORRECT TOP PLATE FOR THIS  WORTH  $60,000.00 USD (81,500.00 CDN) WITH A 1 YEAR WAIT FROM SLASHBUSTER - TAKE IT FOR $40,000.00
4) PROMAC Model RGP  52 INCH BRUSH CUTTER   TREE CUTTER UP TO 6 INCHES  - GRINDS AND MULCHES BRUSH - BLUEBERRIES PLANTS  - TAKE IT FOR $15,000.00
5)  LANDHERO NEW 67 INCH BRUSH RAKE FOR 200-300 CLASS EXCAVATORS -  90 MM FRONT PINT 80 MM REAR PIN - TAKE IT FOR $6000.00
6) AS NEW TEREX LARGE 160 HP DUAL DRUM ROCK AND CONCRETE GRINDER LOW HOUR READY TO WORK $125,000.00 GRINDER WITH 90MM FRONT PINT 80 MM REAR PIN TAKE IT FOR $50,000.00
7) STANLEY 200-380 CLASS HS2000 20000 FT LB PLATE COMPACTOR/DRIVER 80 OR 90 MM PINS WITH 15 INCHES BETWEEN EARS - $20,000.00 + PLATE COMPACTOR TAKE IT  FOR $8000.00
8) ESCO 48 INCH 2.5 YARD DIGGING BUCKET C/W 90 MM PINS AND WELDED CUTTING EDGE ON TEETH - AS NEW EXTREME DUTY 90 MM PINS AS NEW COST $15,0000.00 USD - TAKE IT FOR $8000.00
9) AS NEW FELCO COMPACTOR BUCKET ALL IN ONE UNIT - STOP CHANGING BASK AND FORTH TO DO BACKFILLING IN TRENCHES ETC NEW COST $36,000.00 - TAKE IT FOR $15,000.00 - NOTE SITTING IN OUR LANGLEY BC YARD
10) 85K NEW KISHOFFER 20,000 LB CAPACITY DEMOLITION - LOGGING  3 YARD C/W PIN GRABBER MOUNT TOP FIT RIGHT ON THIS MACHINE NEW COST $85,000.00 - TAKE IT FOR $45.000.00  - NOTE SITTING IN OUR LANGLEY BC YARD
11) NEW HENSLEY ADCO 30 INCH RIPPING V BUCKET  MAKES SHORT WORK OF FROZEN OR HARD SANDSTONE OR SHALE ETC - NEW COST $15,000.00 USD  - TAKE IT FOR $8,000.00
12) MP MACFREY - SONS AMERICAN BUILT ALL AR400 STEEL 2.5 YARD DITCHING - TRENCHING V BUCKET  C/W NEW 90 MM PINS SET UP FOR THIS MACHINE NEW COST $15,000.00 USD TAKE IT FOR $8,000.00
13) ALLU PM200 ROTARY DRUM SOILS-SLUDGE-COMPOST MIXING 200-350 CLASS WITH  CEMENT SLURRY INJECTED INTO THE PROTECTED SPRAY HOSE -  SET UP WITH 90 MM PINS FOR THIS MACHINE - NEW  COST $100,000.00
TAKE THIS AS NEW UNIT FOR $30,000.00
14)  2020 OKADA 7500 FT LB  HYDRAULIC BREAKERS/HAMMERS  FRESH 0 HOUR OKADA FACTORY $35,000.00 STAGE  II REBUILD WITH NEW PISTON ALL  NEW BUSHING - SEALS  NEW MOIL POINT AND 1 AS NEW SPARE MOIL POINT
TAKE THIS $100,000.00 HAMMER FOR $60,000.00  WITH 6 MONTHS WARRANTY FROM OKADA
15) NEW OKADA CUT 8O FR COMBINATION CONCRETE - REBAR - STEEL BEAM SHEAR C/W 80MM PINS FOR THIS MACHINE - NEW COST $80,000.00 - TAKE IT FOR $35,000.00 - NOTE SITTING IN OUR LANGLEY BC YARD
16) CP 24 INCH EXTREME DUTY 4 SHANK STAGGERED LONG RIPPERS BUCKET C/W 3 NEW TIGER TEETH AND ALL NEW RIPPER TEETH - $15,000.00 CUSTOM BUILT WITH 16 WEEKS LEAD TIME - TAKE IT FOR $8,000.00
17) AS NEW HYDRAULIC FLOW COMBINER VALVE TO TAKE VOLUMES FROM TWO PUMPS WITH FOOT PEDAL ON-OFF SWITCH OR CONTROL PANEL FULL TIME SWITCH - THIS IS FOR RUNNING ATTACHMENTS THAT REQUIRE HIGHER FLOW VOLUMES LIKE GRINDERS - BRUSH CUTTER - CRUSHER BUCKET - HYDRAULIC HAMMERS ETC THIS IS AT OUR  YARD LANGLEY BC
BUT LEAVES YOUR MAIN FUNCTIONS RUNNING SO TO MAKE MACHINE SMOOTH AND RESPONSIVE TAKE THIS VALVE FOR $3000.00
18) SET OF KOMATSU FACTORY AUXILIARY  PIPING PLUS SET OF PIPING FOR CASE DRAIN LINE  FOR ATTACHMENTS - THESE ARE AT OUR YARD LANGLEY BC
19) NEW $220,000.00 2021 HYDRARAM 175 HYD HP SHEET PILE DRIVER 45-65 TON CLASS TAKE FOR $100,000.00 (with machine only)
20) LOW HOUR $125,000.00 TEREX WS-120MD 160 HYD HP DUAL DRUM GRINDER 30-50 TON EXCAVATOR TAKE FOR $40,000.00
21) NEW $85,000.00 KINSHOFFER LOG LOADER - 3 3 YARD DEMOLITION 360 DEGREE ROTATION 20K CAPACITY GRAPPLE TAKE FOR $40,000.00
22) OKADA FACTORY REBUILT 0 HOUR 2020 $110,000.00 HYDRAULIC HAMMER/BREAKER C/W TWO NEW MOIL POINTS TAKE FOR $60,000.00
23) 3 X HENSLEY HPX 400-490 KOMATSU 30-46-70 IN HD BUCKETS ALL AS NEW OR NEW - TAKE ALL THREE FOR $25,000.00
24) NEW 2023 PRIMARY DEMOLITION PROCESSOR & 2023 DEMOLITION SORTING GRAPPLE - TAKE BOTH WITH MACHINE $50,000
250  AS NEW $80,000.00 OKADA CUT 80FR STEEL - CONCRETE DEMOLITION SHEAR - TAKE FOR $35,000.00
26) ESCO 400 - 450CLASS HEAVY DUTY 24 INCH BUCKET C/W EXTREME DUTY RIPPER SHANK HOLDER - FOR RIPPING HARD GROUND AND CLEANING BETWEEN PILES IN FOUNDATION TAKE IT FOR $6000.00
Company KOMATSU HEAVY EQUIPMENT
Factory or Website Url https://www.komatsu.com/
Fuel Type Diesel
Transmission Automatic
Website To Display Url https://www.komatsu.com/products/excavators/
Year of Vehicle Registration 2012
