JBL PartyBox 720 15Hr Portable IPX4 Outdoor Party Wireless Bluetooth Speaker
Posted Date: Apr 28th, 2026 at 10:50 AM
0.0 star 231 views
Price: $550.00
Power Input
100 – 240 V ~ 50 / 60 Hz
Signal-to-Noise Ratio
> 80dB
Output power (W)
800 W RMS (IEC60268)
Audio Specifications
Frequency Response
32 Hz – 20 kHz
Transducer
2 x 9 inch (243 mm) woofers, 2 x 1.25 inch (30 mm) dome tweeters
Dimensions
Dimensions (Width x Height x Depth) (cm)
41.6 x 94.2 x 40.6
Dimensions (Width x Height x Depth) (in)
16.38 x 37.1 x 16.0
Weight (kgs)
31
Weight (lbs)
68.3
Control and Connection Specifications
USB-C Charge Out
PDO (5 V / 3 A, 9 V / 3 A, 15 V / 2 A, 20 V / 1.5 A), PPS (5 - 11 V / 2.7 A, 5 - 16 V / 1.85 A)
Bluetooth Profile
A2DP V1.4, AVRCP V1.6
Bluetooth Transmitter Frequency Range (GHz)
2.4 - 2.4835
Bluetooth Transmitter Modulation
GFSK, π/4 DQPSK, 8DPSK
Bluetooth Transmitter Power
≤ 18 dBm (EIRP)
Bluetooth version
5.4
Aux-In
250 mV RMS (3.5 mm connector)
Mic-In
20 mV RMS
Guitar-In
100 mV RMS
Line-In
100 mV RMS
Bluetooth Input (dBFS)
-12
USB Format
FAT16, FAT32
Portable Speaker Specs - Supported Music File Formats
.MP3, .WAV, .FLAC
Battery
Cable Type
AC power cable
Cable Length (ft)
6.6
Cable Length (m)
2
Battery Type
2 x JBL BATTERY 600, Li-ion 99.02 Wh
Battery Charge Time (hours)
3
Maximum music playing time (hrs)
15
Features
3.5 mm audio cable Input
Yes
Bluetooth
Yes
Lightshow
Yes
Supports Auracast
Yes
Waterproof
Yes
XLR inputs
Yes
Dual Mic & Guitar inputs
Yes
IP Code
IPX4
JBL PartyBox App
true
Brand Name JBL PartyBox 720
Condition:
New
Warranty Available Yes
Connectivity Bluetooth
Equipment type Speaker
