XC50 Xcentric Crusher Bucket 130 Cubic Yards Per Hour Was 150000 CAD Reduced NOW ONLY 70000 CAD
Posted Date: Jun 28th, 2026 at 01:33 AM
0.0 star 153 views
Price: $70000.00
🚜 XC50 XCENTRIC CRUSHER BUCKET
130+ CUBIC YARDS PER HOUR
WAS $150,000 CAD — NOW ONLY $70,000 CAD
🌎 THE WORLD'S MOST ADVANCED EXCAVATOR JAW CRUSHER BUCKET
Replace Mobile Jaw Crushers Costing $400,000+
If you're hauling concrete, asphalt or rock to a stationary crusher, you're spending money you don't need to.
With the Xcentric XC50, your excavator becomes a complete mobile crushing plant.
One Machine • One Operator • One Engine • One Lowbed Move
Crush directly into trucks or stockpiles without the expense of separate crushers, loaders and conveyors.
✅ WHY BUY THE XC50?
✔ Produces 130+ cubic yards per hour
✔ Loads directly into 10 tandem 13-yard dump trucks every hour
✔ Adjustable finished product from ½" minus to 5"
✔ Granulometry adjustment in under 2 minutes
✔ Crushes:
  • Reinforced concrete (including rebar)
  • Granite
  • Basalt
  • Asphalt
  • Brick
  • Demolition debris
  • Wet or dry materials
✔ No conveyor belts
✔ No extra loader required
✔ Approximately 50% lower fuel consumption
✔ Lower insurance costs
✔ Lower maintenance costs
✔ Fast setup and teardown
✔ Ideal for:
  • Demolition
  • Quarrying
  • Material Recycling
  • Road Construction
  • Remote Projects
  • Aggregate Production
💰 WHY CONTRACTORS ARE SWITCHING
Compared to traditional mobile jaw crushers, the XC50 offers:
✔ One operator instead of multiple operators
✔ One excavator instead of multiple machines
✔ No separate loader
✔ No conveyors to repair
✔ Lower transportation costs
✔ Lower operating costs
✔ Lower fuel consumption
✔ More production with fewer moving parts
📋 UNIT DETAILS
Model: XC50
Year: 2020
✔ Low Hour Unit (Minimal Use During COVID)
✔ Approximately 90% Original Jaws Remaining
✔ Approximately 90% Original Paint & Decals
✔ Excellent Working Condition
Weight
6,250 kg
Carrier Size
38–65 Ton Excavators
45 Ton+ Recommended
Currently configured for:
• Volvo EC480LC
•Komatsu PC 400-490 Excavators
Requires only:
• Two-way Auxiliary Hydraulic Circuit
• Case Drain Line
Move it easily between multiple excavators and multiple job sites.
⚙ ENGINEERING ADVANTAGES
The XC50 isn't simply another crusher bucket.
It incorporates multiple patented technologies unavailable in conventional crusher buckets.
✅ Patented Circular Jaw Motion
Unlike conventional crusher buckets that compact material and reduce production, the patented circular jaw motion:
✔ Produces more material
✔ Prevents compaction
✔ Maintains continuous flow
✔ Delivers significantly higher output
✅ Patented Anti-Stagnation Plate
Continuously pushes material through the crushing chamber preventing:
✔ Bridging
✔ Blockages
✔ Production interruptions
✅ High Inertia Dual Hydraulic Drive
Two hydraulic motors provide enormous starting torque even when the jaws begin fully closed.
Benefits include:
✔ More crushing force
✔ Higher production
✔ Less excavator stress
✔ Faster crushing cycles
✅ Double Effect Hydraulic System
If material jams:
Simply reverse the jaw hydraulically.
No need to empty the bucket.
Resume crushing immediately.
✅ Cross Top Jaw Design
Perfect for:
✔ Wet concrete
✔ Sticky demolition debris
✔ Clay
✔ Asphalt
✔ Wet aggregate
Wet material keeps flowing instead of packing inside the crusher.
✅ Anti-Skid Transmission
Higher production.
Less slippage.
Fewer jams.
Longer drivetrain life.
✅ Granulometry Adjustment
Finished product adjusts from approximately:
20 mm (¾") to 210 mm (8")
Adjustment takes less than two minutes.
✅ Minimal Maintenance
Approximately 50-hour grease intervals
Approximately 80% fewer wear parts than conventional crusher buckets.
NO:
• Springs
• Toggles
• Complex linkage systems
Lower maintenance.
More production.
Less downtime.
🏗 PREMIUM EUROPEAN ENGINEERING
Manufactured in Spain using premium materials including:
✔ HARDOX® 400 Wear Steel
✔ STRENX® Structural Steel
✔ Protected Internal Flywheels
✔ Reinforced Housing
✔ Cantilever Loading Mouth
✔ Cross Top Jaw Design
Built for maximum durability under extreme quarry and demolition conditions.
♻ PERFECT FOR
✔ Concrete Recycling
✔ Quarry Operations
✔ Road Construction
✔ Demolition
✔ Rock Crushing
✔ Asphalt Recycling
✔ Municipal Projects
✔ Remote Crushing
✔ Pipeline Construction
✔ Land Development
💰 PRICE
Current New Replacement Cost
Over $250,000 CAD
PLUS
• Shipping
• Import Costs
• Approximately 6–7 Week Delivery
🔥 OUR PRICE
ONLY $70,000 CAD
This is believed to be the ONLY used XC50 currently offered for sale anywhere in the world.
🎥 WATCH THE XC50 IN ACTION
XC50 Model Demonstration
Product Overview
https://www.youtube.com/watch?v=ofOo4Xq6O1s
Granulometry Adjustment Comparison
Complete Xcentric Video Library
📖 FACTORY MANUAL
🌐 MANUFACTURER INFORMATION
💥 ALSO AVAILABLE
ROCKTEC TERMINATOR TX750
75,000 FT-LB HYDRAULIC DROP HAMMER
Ideal companion to the XC50.
Break:
✔ Concrete walls up to 4 feet thick
✔ Massive boulders
✔ Bedrock
✔ Oversized concrete
Then immediately crush the material with the XC50 into reusable aggregate.
🚚 SHIPPING
✔ Fast Canada-wide Shipping
✔ We Load Your Carrier
✔ Specialized 12,000 lb 4WD Forklift On Site
Pickup Location:
1921 Lakeview Road
Cambridge-Narrows, New Brunswick
Canada
E4C 1N1
📞 CONTACT
Frank Rayner
Call / Text
604-476-7777
WhatsApp
+1-604-476-7777
Email
[email protected]
Website
https://www.alltrac.co
SERIOUS INQUIRIES ONLY
If this advertisement is online, the XC50 is still available.
This is an exceptional opportunity to purchase one of the most advanced excavator crusher buckets ever built at a fraction of replacement cost.
Construction – Model / Part Number XC50 XCENTRIC JAW BUCKET
Construction – Year of Manufacture 2020
Construction – Technical Specifications 130 YARDS PER HR
Construction – Attachment – Pin Size 100 MM FRONT 100 MM REAR
Construction – Attachment – Weight 6250
Construction – Attachment – Width 49
Construction – Attachment – Capacity 2
