What Is an Eagle in Golf Complete Guide for Beginners
Posted Date: May 1st, 2026 at 04:01 PM
0.0 star 199 views
Golf is a game filled with unique terms, and one of the most exciting achievements on the course is scoring an Eagle in Golf. For beginners, this term might sound confusing at first, but once you understand it, you’ll realize why golfers celebrate it so enthusiastically. In this guide, we’ll break down everything you need to know in a simple and easy-to-understand way.
Understanding Golf Scoring Basics
Before diving into eagles, it’s important to understand how scoring works in golf. Each hole on a course has a “par,” which represents the number of strokes an average golfer is expected to take to complete it.
Here’s a quick breakdown of common golf scores:
  • Par – Completing the hole in the expected number of strokes
  • Birdie – One stroke under par
  • Eagle – Two strokes under par
  • Bogey – One stroke over par
So, if a hole is a par 5 and you finish it in just 3 strokes, you’ve scored an eagle. That’s a big deal, especially for beginners.
What Does an Eagle Mean in Simple Terms?
An eagle is when a golfer completes a hole in two strokes fewer than the par. It’s considered one of the best scores you can achieve on a single hole, just below the rare albatross (three under par).
For example:
  • Par 3 → Score of 1 (Hole-in-one)
  • Par 4 → Score of 2
  • Par 5 → Score of 3
Achieving this requires a combination of skill, accuracy, and sometimes a bit of luck.
Why Is It Called an “Eagle”?
Golf uses bird names to describe scores under par. It started with the term “birdie,” which meant something excellent or impressive in early American slang. As golfers began achieving even better scores, they used bigger birds to represent greater achievementshence the term eagle.
It symbolizes something powerful and rare, just like the score itself.
How Difficult Is It to Score an Eagle?
For beginners, scoring an eagle can feel almost impossible and honestly, it’s not easy even for experienced players. It usually requires:
  • A long and accurate drive
  • A precise second shot
  • Excellent putting skills
Most amateur golfers may go many rounds without ever scoring one. However, with consistent practice and smart strategies, it becomes more achievable over time.
Common Situations Where Eagles Happen
Eagles are more likely on certain types of holes:
Par 5 Holes
This is where most golfers have their best chance. A strong drive followed by a great second shot can put the ball close to the hole, making an eagle possible.
Par 4 Holes
Getting an eagle here usually requires holing out from the fairway or hitting an incredible drive that lands near the green.
Par 3 Holes
An eagle on a par 3 is simply a hole-in-one, which is rare but unforgettable.
Tips to Improve Your Chances
If you’re aiming to achieve this milestone, here are some beginner-friendly tips:
1. Focus on Distance and Accuracy
Work on hitting longer and straighter drives. The closer you get to the green in fewer shots, the better your chances.
2. Improve Your Approach Shots
Your second shot is crucial. Practice hitting irons or fairway woods with precision.
3. Master Your Putting
Even if you reach the green in two shots, you still need to sink the putt. Spend time improving your short game.
4. Play Smart
Don’t always aim for risky shots. Sometimes playing strategically gives you a better chance of setting up an easy putt.
Role of Technology in Tracking Progress
Modern tools have made it easier for golfers to track their performance. Using a golf scoring app helps you analyze your rounds, monitor your progress, and identify areas for improvement.
Many players rely on a golf scoring app to keep accurate records, track statistics, and even measure how often they come close to scoring lower-than-par results. This data can be extremely helpful for beginners trying to improve their game.
Why Scoring an Eagle Feels Special?
There’s something incredibly satisfying about achieving this score. It’s not just about the numbers it’s about the effort, skill, and excitement that come with it.
For beginners, it can be a major confidence boost. It shows that your practice is paying off and that you’re capable of playing at a higher level.
Common Mistakes Beginners Make
While chasing big scores, beginners often make a few mistakes:
  • Trying too hard for power instead of accuracy
  • Ignoring short game practice
  • Taking unnecessary risks
  • Not learning course management
Avoiding these mistakes can actually increase your chances of better scores over time.
Eagle vs Birdie: What’s the Difference?
It’s easy to confuse these two terms, but the difference is simple:
  • Birdie = 1 stroke under par
  • Eagle = 2 strokes under par
While birdies are more common, eagles are rarer and more rewarding.
Can Beginners Really Score One?
Yes, beginners can achieve it but it usually takes time, patience, and consistent practice. Most first-time eagles happen on par 5 holes where players get a bit more room to recover from mistakes.
The key is not to rush. Focus on improving your overall game, and the results will follow naturally.
Final Thoughts
Understanding scoring terms is an important part of becoming a better golfer, and learning about an Eagle in Golf is a great place to start. While it’s a challenging achievement, it’s not out of reach.
With practice, smart play, and the help of modern tools, you can steadily improve your performance. Stay patient, enjoy the process, and celebrate every small win along the way. One day, that perfect shot might just lead you to your very first eagle.
Frequently Asked Questions (FAQs)
1.What is an Eagle in Golf?
An Eagle in Golf means completing a hole in two strokes under par. For example, finishing a par 5 hole in just 3 strokes is considered an eagle.
2.How rare is an eagle for beginners?
Eagles are quite rare for beginners because they require excellent distance, accuracy, and putting skills. Most new golfers may take time before achieving one.
3.Is an eagle better than a birdie?
Yes, an eagle is better than a birdie. A birdie is one stroke under par, while an eagle is two strokes under par.
4.What is better than an eagle in golf?
The only common score better than an eagle is an albatross (three strokes under par), which is extremely rare.
5.Can a beginner score an eagle?
Yes, beginners can score an eagle, especially on par 5 holes. However, it usually requires a combination of good shots and a bit of luck.
