Werk-Brau D-LOCK D-Lock Hydraulic Tilt Coupler FITS EXCAVATORS C/W 65 MM PINS WAS BUILT FOR ON A JOHN DEERE 135G EXCAVATOR
Posted Date: May 21st, 2026 at 09:01 PM
Thumb 1 Thumb 2 Thumb 3 Thumb 4 Thumb 5 Thumb 6 Thumb 7 Thumb 8 Thumb 9 Thumb 10 Thumb 11 Thumb 12 Thumb 13 Thumb 14 Thumb 15 Thumb 16 Thumb 17
0.0 star 253 views
Price: $6000.00
Werk-Brau D-LOCK D-Lock Hydraulic Tilt Coupler FITS EXCAVATORS C/W 65 MM PINS WAS BUILT FOR AND USED ON A JOHN DEERE 135G EXCAVATOR As new low hour unit used 1 job gives another 18 inches of 180 degree tilting to your excavator reach WITH A HYDRAULIC PIN GRABBER COUPLER LOW HOUR TAKE OFF C/W HYDRAULIC HOSES - READY TO MOUNT AND WORK BUILT THE 25TH DAY OF THE 5TH MONTH OF 2022 WAS FROM John Deere 135G RTS WITH THE FOLLOWING DIMENSIONS PINS SIZE - 2.56 INCH OR 65 MM DISTANCE BETWEEN EARS -10.10 INCH OR 2.56 MM FITS ANY OF THE FOLLOWING INCLUDING: Case CX130 Case CX135SR Caterpillar 311C Caterpillar 312B Caterpillar 312C Caterpillar 314C LCR Daewoo SOLAR 130LC-V Daewoo SOLAR 140LC-V Hitachi EX 110-5 Hitachi Zaxis 120 Hitachi Zaxis 135US John Deere 120C John Deere 135C RTS Kobelco 115SRDZ Kobelco 135SRLC Komatsu PC 100-6 Komatsu PC 120-6 Komatsu PC 128US-2 Komatsu PC 128UU-2 Komatsu PC 138USLC-2 Link-Belt 130LX Link-Belt 135SA Link-Belt 2650 QUANTUM New Holland EH130 Takeuchi TB1140 Terex TXC 140LC-1 Werk-Brau manufactures all attachments to O.E.M. specs for all makes and models of excavators, mini-excavators, and backhoes. Features: THIS UNIT FEATURES: Automatic front lock – Locks the front pin in the event the rear pin is not secured Multi-pin centers, picks up all attachments in the same weight class with the same pin diameter Highly visible front lock indicator Triple sealed actuator Safety system does not rely on gravity Dual pin lock – Locks both front and rear pins in the event of loss of engagement force Unlock process is designed to release only when the operator intends to do so, in a controlled and safe manner Simple yet safe unlock procedure eliminates accidental releases Compact design – Improving machine performance No greasing or lubrication required Only requires four hydraulic lines Up to 180 degrees of tilt Fully guarded hoses WATCH THE WERBRAU VIDEO ( copy and paste ) https://werk-brau.com/wp-content/uploads/2023/09/tilt-coupler-Original.mp4?_=1 Automatic front lock – Locks the front pin in the event the rear pin is not secured Multi-pin centers, picks up all attachments in the same weight class with the same pin diameter Highly visible front lock indicator Safety system does not rely on gravity Dual pin lock – Locks both front and rear pins in the event of loss of engagement force Unlock process is designed to release only when the operator intends to do so, in a controlled and safe manner Simple yet safe unlock procedure eliminates accidental releases Only requires two hydraulic lines Compact design – Improving machine performance No greasing or lubrication required WATCH THE WERBRAU VIDEO FOE THE D-LOCK COUPLER https://youtu.be/c2Q7Kw4o_JA * The simple, easily serviceable design of the D-Lock combined with world leading safety features makes the D-Lock the safest coupler on the market today. The D-Lock Coupler is dual locking, meaning attachments remain securely engaged on both pins in the event of loss of engagement force. A compact design of only seven moving parts (fewest in the industry), requiring only two hoses, no greasing and no complicated operating sequence to follow are just a few of the features which put the D-Lock at the forefront of coupler performance worldwide. D-LOCK® COUPLER U.S. patent no. 9,677,245 When safety is paramount Automatic front lock – Locks the front pin in the event the rear pin is not secured Multi pin center, picks up all attachments in the same weight class with the same pin diameter OR less Highly visible front lock indicator Safety system does not rely on gravity Dual pin lock – Locks both front and rear pins in the event of loss of engagement force Simple yet safe unlock procedure eliminates accidental releases. Unlock process is designed to release only when the operator intends to do so, in a controlled and safe manner, and prevents accidental release Patented slideKomatsu lock design* Compact design – Improving machine performance Only requires two hydraulic lines Fewest parts in industry (8) No greasing or lubrication required Available for all machines from 1.5 to 120 tons Werk-Brau D-Lock Tilt Coupler Enhances Excavator Productivity Werk-Brau presents the D-Lock Tilt Coupler which allows an operator to tilt the attachment instead of repositioning the excavator for enhanced productivity and versatility on each jobsite. A compact narrow body allows better visibility and performance, while the rugged, triple sealed power actuator allows trouble-free operation which is virtually maintenance-free. With up to 180-degrees of tilt, the D-Lock Tilt Coupler enhances productivity thus increasing profitability by accomplishing tasks quicker with fewer excavator moves. These performance boosting couplers are ideal for mini/compact excavators to 5 ton, and full-size excavators to 35 MT. This unique design includes world leading safety features like automatic front lock, dual pin locking, and a patented slide lock design. Dual locking design ensures that attachments remain securely engaged on both pins in the event of loss of engagement force. The simple yet safe unlock procedure ensures that the unit releases only when intended to, in a controlled, safe manner that prevents accidental releases. A multi pin center picks up all attachments in the same weight class with the same pin diameter. Just four hydraulic lines are required for installation, with no greasing or lubrication needed. Each unit includes a highly visible front lock indicator. Automatic front lock feature locks the front pin in the event the rear pin is not secured. The sliding jaw primary lock allows for multi pin centers to be accepted and is operated by a unique double skinned, double acting hydraulic cylinder utilizing full system pressure. No head feed tube or pressure reducer is required. The D-Lock Coupler fully complies to AS4772-2008 and EN474 Standard and expected forthcoming ISO international standards. Every D-Lock Coupler includes a dual pin locking (DPL) system. Front lock automatically engages the moment the rear jaw Is activated, negating any chance of the bucket falling off if the operator misses the rear pin. DPL safety system locks both front and rear pins in the event of loss of engagement forces. DPL safety system ensures that attachments cannot swing on the front pint in the event of loss of engagement forces. Reason for Sale * Selling due to a family health matter requiring relocation from the Fraser Valley, BC * Severe smog and forest fire smoke caused extreme COPD, prompting the move * Assets are being reduced to eliminate ongoing storage costs * All items are properly stored, maintained, and priced for immediate sale * Listings are removed promptly once sold Loading, Shipping & Logistics * Specialized 4-Wheel Drive 12,000 lb Forklift on Site * We load your carrier * Fast shipping quotes available * Buyers may use their own shipper Shipper Address: 1921 Lakeview Road Cambridge-Narrows, NB E4C 1N1 CONTACT — SERIOUS INQUIRIES ONLY Frank 604-476-7777 (Call or Text) ☎️ Toll-Free: 1-(833)-693-9323 WhatsApp: +1-604-476-7777 Email: [email protected] Website: www.alltrac.co
Construction – Brand / Manufacturer John Deere
Construction – Year of Manufacture 2021
Construction – Model / Part Number JOHN DEERE 135G EXCAVATOR
