Want to Merge Contacts with Full Information Intact Keep Every Detail Safe
Posted Date: May 4th, 2026 at 06:44 PM
0.0 star 174 views
Price: $29.00
Contacts stored in multiple VCF files often create confusion when everything needs to be combined. Files from different apps and devices may lead to missing fields or mixed details during manual merging. It becomes quite difficult to maintain names, phone numbers, emails, and other information. Softken Software Merge vCard Software helps merge VCF files into one file while keeping every contact detail exactly the same. Multiple vCard files can be added together, even complete folders, and merged in one go. All details like names, phone numbers, email IDs, addresses, and other fields remain unchanged after merging. A preview option allows checking files before combining, which helps maintain accuracy. It is easy for the user to import the contact files without any issues of compatibility problems. The tool interface is friendly and easy to use. Data security is assured at all times when using the software. A reliable way to merge vCard files and keep contacts complete and well-organized in one place.
Condition New
Warranty Offered No
Origin Country United States
Availability In Stock
Software Type Utility
License Type Multi User
Delivery Type Digital Download
