SUCH Force Sensor
Posted Date: Jul 15th, 2026 at 08:14 AM
0.0 star 115 views
Price: $436.00
SUCH.com offers compression force sensors, tension force sensors, combined tensile and compression force sensors, multi-axis force sensors, and miniature force sensors. The measurement range of these force sensors covers from small N-level ranges to high-load specifications of hundreds of kN, allowing users to select the appropriate model for different application environments.
SUCH force sensors use high-precision strain measurement technology and support multiple signal formats, including analog voltage output and digital communication interfaces.
SUCH force sensors can be connected to data acquisition systems, PLCs, display instruments, and industrial control equipment to achieve real-time force monitoring.
SUCH force sensors convert applied pressure, tension, or multi-directional forces into standard electrical signal outputs, helping users achieve accurate force monitoring and data analysis. Force sensors are suitable for industrial automation, equipment testing, and smart manufacturing, providing customers with high-precision and high-stability force measurement solutions.
