STANLEY 200-380 CLASS HS2000 20000 FT LB PLATE COMPACTOR/DRIVER AS NEW READY TO WORK
Posted Date: Jan 18th, 2026 at 12:55 AM
5.0 stars 439 views
Price: $6000.00
AS NEW PLATE COMPACTOR WITH 80 MM PINS - REMOVE BUSHINGS TO GO TO 90 MM  PIN BOSSES
Features and Specifications:
Pins: New 80 mm pins (currently bushed down to 80 mm; can be returned to 90 mm)
Hoses: New hoses included
Flow Control Valve: Internal flow control valve included
Ear Spacing: 15 inches between the ears
Condition: Great low-hour condition, ready to work
Performance:
Vibrations: 2100 per minute
Centrifugal Force: 20,000 lb
Hydraulic Pressure: 1800-2250 psi
Baseplate Size: 32 in x 42 in
Key Features:
High Centrifugal Force: Ranges from 3,400 to 20,000 pounds, more than a walk-behind plate compactor.
Ease of Use: Eliminates the need for a person working down in the trench.
Valve Block Cover: Provides additional protection from accidental mishaps.
Protected Hydraulic Hoses: Nylon sleeve cover and precisely routed to minimize movement and interference.
Flat-Top Models: Offer compatibility with many mounting configurations.
Shock Mounts: Four heavy-duty, industrial-grade shock mounts for even vibration distribution, improving efficiency and work quality.
Pin Grabber Top Mounting System: Suitable for any 300-class excavator by removing the bore bosses to return to 90 mm pins.
Adaptable Pin Bores: Bushed down for any 200-240 class excavator.
Operational Requirements:
Flow: Requires 42 GPM
Compatibility:
Current Setup: John Deere/Hitachi 200 to 380 series excavator with pin grabber coupler that accepts 80 and 90 mm pins .
Also Set Up For: our Komatsu PC 200 - 390LC-10 and more excavators
Pricing:
New Cost: Over $22,000.00
Sale Price: $6,000.00
Location and Contact:
Shipping: Fast shipping available at great rates.
Contact: Frank at 604-476-7777
Additional Ads:
Check my 190 listed ads for more plate compactors
Construction – Technical Specifications Vibrations: 2100 per minute Centrifugal Force: 20,000 lb Hydraulic Pressure: 1800-2250 psi Baseplate Size: 32 in x 42 in
Mark Henry Feb 19th, 2026 at 17:27
Absolutely satisfied with my purchase from EzeAD! The Stanley HS2000 Plate Compactor was exactly as described in great condition and ready to work right away. The whole buying process on EzeAD was smooth, easy, and trustworthy. If you're looking for a reliable platform to buy or sell quality equipment, I highly recommend EzeAD!
