Simex TF 1100 Dual Drum Cutter Head for 2035 Ton Excavators Outperforms Hydraulic Hammers 35x
Posted Date: Jun 9th, 2026 at 01:52 AM
Thumb 1 Thumb 2 Thumb 3 Thumb 4 Thumb 5 Thumb 6 Thumb 7 Thumb 8 Thumb 9 Thumb 10 Thumb 11 Thumb 12 Thumb 13 Thumb 14 Thumb 15 Thumb 16 Thumb 17 Thumb 18
0.0 star 147 views
Price: $50000.00
Stop Wasting Time with Hydraulic Hammers. Quadruple Your Production Today.
Are you tired of slow, noisy, and high-maintenance hydraulic hammers stalling your progress? Step up to the ultimate excavation powerhouse. The Simex TF 1100 Dual Drum Cutter Head is engineered to completely replace traditional hammers, outperforming them by 3 to 5 TIMES in trenching, rock facing, and continuous excavation.
Whether you are cutting through solid rock, profiling concrete, or digging pipelines, this heavy-duty rotary cutter delivers cleaner cuts, faster completion times, and a massive boost to your bottom line.
🔥 Why the Simex TF 1100 Outperforms the Competition:
  • Massive 3x-5x Production Boost: Excavate, trench, and face rock up to five times faster than traditional hydraulic breakers.
  • Low Noise & Minimal Vibration: Ideal for strict urban job sites, sensitive utility areas, and close-quarters demolition.
  • Flawless Precision: Achieve perfect profiling and flat-wall finishing on the first pass—no extra clean-up crew needed.
  • Bulletproof Reliability: Equipped with an advanced sealing system to completely block out dust, dual support bearings per drum, and replaceable anti-wear plates for continuous, zero-downtime operation.
⚙️ Premium Technical Specifications:
Engineered specifically for 200–350 Class (20–34 Ton / 44,000–80,000 lb) carrier excavators.
  • Reference Number: AMH088
  • Cutting/Drum Width: 850 mm (34 inches)
  • Nominal Power: 90 kW (122 HP)
  • Aggressive Rotation Torque: 20 kNm (14,750 lbf·ft)
  • Massive Cutting Force: 61 kN (13,700 lbf)
  • Operating Pressure: 400 bar (5800 PSI)
  • Oil Flow Requirement: 170–250 L/min (45–66 GPM)
  • Base Unit Weight: 1,340 kg (2,950 lbs) (Includes pin-on mounting bracket c/w pins!)
🛠️ Versatile, All-Industry Applications:
  • Trenching & Utility Pipeline Installation
  • Rock & Concrete Wall Profiling / Facing
  • Tunnel Excavation & Quarry Operations
  • Dredging, Marine Construction & Underwater Demolition
  • High-Precision Final Surface Finishing
📺 See It in Action – Performance Comparison Videos:
Don't just take our word for it. Watch the mechanical superiority of a rotary grinder over a breaker:
🚚 Availability & Immediate USA-Wide Shipping!
This unit is ready to go to work for you. Skip the factory backorders and secure this attachment immediately.
  • 📍 Physical Location: 226 High St, Randolph, MA 02368, United States
  • 📦 Shipping: Fast, reliable freight shipping available USA-wide.
  • 🌐 Browse More Heavy Equipment: gorillahammers.com/
☎️ Lock in Your Price – Contact Us Now!
Heavy-duty attachments like this sell fast. Don't let your competition grab it first. Call, text, or WhatsApp today for a fast quote.
Construction – Heavy Equipment – Machine Height 1310
Construction – Heavy Equipment – Machine Width 850
Construction – Heavy Equipment – Bucket/Attachment Capacity 850
Construction – Heavy Equipment – Hydraulic Pressure 400
Construction – Heavy Equipment – Engine Power 122
Construction – Heavy Equipment – Operating Weight 1340
Construction – Technical Specifications Carrier Range: 20–34 Ton (200-350 Class) | Oil Flow Rate: 170–250 L/min | Rotation Torque: 20 kNm (14,750 lbf·ft) | Cutting Force: 61 kN (13,700 lbf) | Double support bearings | Dust-sealed drums | Replaceable anti-wear plates.
Construction – Fuel / Power Type Other
Construction – Location 226 High St, Randolph, MA 02368, United States
Construction – Condition New
Construction – Model / Part Number TF 1100
