RUBBER TRACKS 230x96x30
Posted Date: Jul 23rd, 2025 at 03:47 AM
0.0 star 139 views
Fits Kubota KX41, KX36, KX014 Mini Excavators
🔩 Product Description:
Upgrade or replace your mini excavator’s tracks with high-performance rubber tracks (230x96x30) designed specifically for Kubota KX41, KX36, and KX014 models. These tracks offer superior traction, stability, and durability across a wide range of terrains — perfect for construction, landscaping, and agricultural applications.
  • Track Size: 230 mm width x 96 pitch x 30 links
  • Compatibility: Kubota KX41, KX36, KX014 (and other models using same size)
  • Material: Heavy-duty rubber compound with steel core for long service life
  • Performance: Reduced vibration, excellent traction, minimal surface damage
  • Weather Resistant: Built to withstand extreme working conditions and environments
  • Easy Installation: Direct replacement, no modifications required
📦 Application Use:
Ideal for:
  • Mini Excavation
  • Trenching
  • Landscaping
  • Utility Work
  • Snow Removal (on soft surfaces)
🛒 Why Choose These Tracks?
  • Precision fitment for Kubota models
  • OEM quality – same fit and performance at a better price
  • Improves machine efficiency & reduces operator fatigue
  • In-stock & ready to ship with fast delivery options
📞 Call or message us today for pricing, bulk orders, or installation advice. Financing and wholesale pricing available!
