ROCKWHEEL 95 HYD HP HYDRAULIC EXCAVATOR TWIN DRUM STUMP GRINDER
Posted Date: May 31st, 2026 at 12:07 AM
100+ Languages Coming Soon
Selected Location
0.0 star 1.1K views
💰 Price: $20,000 CAD
📍 Location: Cambridge Narrows NB
🚛 Shipping Available Across Canada & USA
This Rockwheel Stump Grinder Attachment is in perfect condition and comes equipped with special long-life multi-faced stump grinding teeth designed to aggressively grind stumps, roots, trees, brush, and wood debris.
These units are extremely versatile and can do far more than standard stump grinding.
✅ Stump removal
✅ Tree root removal
✅ Land clearing
✅ Brush grinding
✅ Fire prevention projects
✅ Forestry work
✅ Vegetation management
✅ Utility right-of-way clearing
✅ Demolition cleanup
✅ Trenching applications
✅ Soil mixing / reclamation work
This attachment can quickly eliminate:
It can also help uproot larger trees at the root level and grind the material directly into surrounding soil.
Designed for most:
✔ 90mm pin bores
✔ 14.5 inches between ears
Can also be bushed down to:
✔ 80mm pins for 180–240 class excavators
The Rockwheel installs similarly to a hydraulic hammer using a straightforward:
✔ Two-line hydraulic system
✔ Standard auxiliary hydraulic circuit
Hydraulic lines can be configured based on your machine setup:
With over 13,000 ft-lbs of peak torque, this unit makes quick work of:
💰 Only $20,000 CAD
New replacement cost is approximately:
$90,000+ CAD
Save significantly over buying new.
Rockwheel stump grinding applications:
https://rockzoneamericas.com/applications/stump-grinding
📦 Ship on your account
OR
We can arrange fast shipping at highly competitive freight rates across Canada and the USA.
AllTrac Machinery & Leasing Inc.
Frank Rayner
📞 604-476-7777
☎ Toll Free: 1-833-693-9323
