HUDCO HC30 AND HC50 PLATE COMPACTORS SET UP AS PILEDRIVERS / COMPACTORS
Posted Date: Dec 19th, 2025 at 12:34 AM
Thumb 1 Thumb 2 Thumb 3 Thumb 4 Thumb 5 Thumb 6 Thumb 7 Thumb 8 Thumb 9 Thumb 10 Thumb 11 Thumb 12 Thumb 13 Thumb 14 Thumb 15 Thumb 16 Thumb 17 Thumb 18 Thumb 19
3.0 stars 1.2K views
Price: $5000.00
HUDCO HC30  AND HC50 PLATE COMPECTORS SET UP AS PILEDRIVE / COMPACTOR
WE HAVE BOTH A HC30 SET UP WITH A 22 INCH BOLTED ON BOTTOM PLATE PILE DRIVER
THE TOP PLATE EARS ARE 12.25 INCHES BETWEEN THE EARS WITH 15 1/2 CENTER TO CENTER ON THE 80 MM PINS
WE ALSO HAVE A HC50 SET UP WITH A DUAL BOTTOM PILE DRIVER GUIDES AND HOLDERS
WE HAVE TWO TOP PLATES FOR IT ONE FOR AN EXCAVATOR WITH 90 MM PINS AND ONE FOR A CRANE MOUNTING SYSTEM\
THIS UNIT IS COMPLETE WITH A STAND FOR KEEPING THE UNIT UPRIGHT
TAKE EITHER ONE FOR $5000.00
FRANK 604-476-7777  WE CAN SHIP QUICKLY AND GET GREAT RATES.
Hudco manufactures Hydraulic Vibratory Compactors with standard or custom mountings to fit your excavator or backhoe.
Custom compactor tops are a necessity when using quick attaching bucket mechanisms and custom fitting eliminates the need for additional loose pins and bushings.
Optional accessories include extended base plates, swivel tops, hydraulic valves, and complete hydraulic installations.
Hudco Hydraulic Installations are specialized kits that are fitted to your machine and allow for rapid switching for compactor, hammer or other attachments.
With over thirty years of experience, Hudco technology is responsible for producing the highest quality compactors.
 Compacts soil in trenches, foundations, and on slopes.
 Drives wood, steel sheeting, post, and beams.
 Keeps the crew out of the trench while compacting.
 More productive than hand-held units.
 Custom fit to your excavator Specifications :
SEE THESE UNITS AS A PLATE COMPACTOR   https://youtu.be/jpJ1_-fKqcM
Specifications
SpecificationsHC12HC15HC20HC30HC40HC50
Frequency (cpm)210021002000200020002100
Hydraulic Flow (gpm)1013/2020304255
Pressure (psi)220022002200220022002200
Weight (lbs)450750900160024002600
Bottom Plate (in)12x3116x3624x3429x4034x4734x47
Height (in)203030365050
Machine Sizing (tons)3.5-93.5-95-1010-2222-4522-45
Alice Alice Oct 18th, 2024 at 05:48
alice review
