265/70R16 Winter Tires on Toyota OAM Aluminum Rims - Set of 4
Posted Date: Jan 11th, 2026 at 08:57 AM
0.0 star 569 views
Vehicle Compatibility
Toyota (Best Fit)
Tacoma, 4Runner, FJ Cruiser, and Sequoia. These are a direct, perfect fit.
Chevrolet / GMC
Silverado 1500 and Sierra 1500. The bolts match perfectly. However, Chevy's hub is smaller (78.1mm) than Toyota's (106.1mm). They will bolt on, but some buyers prefer using "hub-centric rings" (a $20 plastic insert) for a smoother ride.
Nissan
Older Frontiers/Xterras (pre-2005) share this pattern. However, 2005+ Frontiers use a different 6x114.3 pattern and will not fit your rims without expensive adapters.
Ford
Ranger (2019+) and Bronco (2021+). These share the same bolt pattern, but the offset might be slightly different.
Weight (kg) 80
Color / Finish Black
Brand / Maker Toyota
Condition Used
Compatibility (Make/Model) Toyota, GMC, Chevy, Ford
Material Type Aluminum
Stock Quantity 4
Part Name / Title Wheels
Company/Maker Website http://Toyota
suvs
