2023 Freightliner M2-106 – HMF 1620-K5 Crane with Steel Deck
Posted Date: Aug 1st, 2025 at 04:20 AM
0.0 star 166 views
Heavy-Duty | Low Hours | Ready for Work
🔧 Truck Specifications:
  • Make/Model: Freightliner M2-106
  • Year: 2023
  • Engine: Cummins L9 Diesel – 350 HP (confirm spec)
  • Transmission: Allison automatic
  • GVWR: ~33,000–56,000 lbs (depending on configuration)
  • Drive: 4x2 or 6x4 (confirm)
  • Cab: Day cab with air-ride driver seat, A/C, and premium trim
  • Mileage: Low – delivery and light-use only
🔧 Crane Specifications:
  • Brand/Model: HMF 1620-K5
  • Type: Articulating (Knuckle Boom) Crane
  • Max Lifting Capacity: ~35,000 lbs (at minimum radius, confirm exact spec)
  • Boom Reach: ~50 ft (with extensions)
  • Controls: Wireless remote control for precise operation
  • Condition: Like-new, minimal use
🔧 Deck Specifications:
  • Material: Heavy-duty steel flatdeck
  • Length: [Insert length if known]
  • Tie-Downs: Multiple integrated load securement points
  • Condition: Excellent – rust-free and work-ready
  • 2023 model year – modern Freightliner comfort and reliability
  • HMF articulating crane for versatile lifting and material handling
  • Remote control operation for increased safety and efficiency
  • Heavy-duty steel deck ideal for construction materials, machinery, or large cargo
  • Perfect balance of lifting capability and transport efficiency
  • Work-ready unit – no setup required
  • Construction and building material delivery
  • Industrial and utility fleet work
  • Heavy equipment transport
  • Municipal and contractor service work
