2022 FASSI F390SE.24 MOUNTED ON 2024 FREIGHTLINER 114SD
Posted Date: Sep 7th, 2025 at 05:14 AM
0.0 star 187 views
Price: $390000.00
2022 FASSI F390SE.24 Mounted on 2024 FREIGHTLINER 114SD πŸš›πŸ—οΈ
Take your industrial operations to the next level with this powerful and reliable 2022 FASSI F390SE.24 crane mounted on a robust 2024 FREIGHTLINER 114SD. This dynamic duo combines unparalleled lifting capabilities with modern engineering, making it an indispensable asset for your business!
Key Features 🌟
  • Unmatched Lifting Capacity: Benefit from the impressive lifting power of the FASSI F390SE.24, designed to handle heavy loads with ease.
  • Advanced Technology: Equipped with the latest hydraulic systems for smooth and precise operations.
  • Durable Design: Built with high-quality materials to withstand the toughest conditions and ensure long-term reliability.
  • Efficiency & Performance: The FREIGHTLINER 114SD chassis provides exceptional maneuverability and control.
Why Choose This Crane? πŸ€”
Whether you’re in construction, logistics, or heavy industry, this crane is your go-to solution for:
  • Construction Projects: Perfect for lifting and moving construction materials effortlessly.
  • Infrastructure Development: Ideal for bridge construction, road work, and other large-scale projects.
  • Industrial Operations: Enhance productivity in factories and warehouses with its versatile applications.
Experience the Benefits 🎯
When you choose the 2022 FASSI F390SE.24 mounted on the 2024 FREIGHTLINER 114SD, you’re investing in:
  • Increased Operational Efficiency: Reduce downtime and accelerate project timelines.
  • Safety & Compliance: Operate with confidence thanks to industry-leading safety features.
  • Superior Return on Investment: Boost your business potential with a crane built to deliver exceptional performance.
If you're ready to elevate your operations, don't miss the opportunity to acquire this outstanding machine. πŸš€
