2021 IMT 50/345 MOUNTED ON 2021 FREIGHTLINER 122SD
Posted Date: Aug 19th, 2025 at 02:12 AM
Price: $214000.00
2021 IMT 50/345 Crane Mounted on 2021 Freightliner 122SD π
Step up your industrial operations with this powerhouse combo! The 2021 IMT 50/345 crane, brilliantly mounted on a robust 2021 Freightliner 122SD, is ready to tackle your most demanding jobs. Whether you're in construction, logistics, or heavy lifting, this dynamic duo promises reliability and efficiency.
Key Features π
- IMT 50/345 Crane: Unmatched lifting capacity and reach, expertly engineered for heavy-duty tasks.
- Freightliner 122SD: Renowned for its durability, this truck ensures smooth transport and stability under load.
- State-of-the-art hydraulic system for precise control and operation.
- Advanced safety features for peace of mind during intense operations.
- Low operational hours, ensuring long-term reliability and performance.
Why Choose This Crane? π€
This setup is not just a purchase; it's an investment in your business's future. With the 2021 IMT 50/345 and Freightliner 122SD, you'll experience:
- Increased productivity with seamless operation capabilities.
- Versatility for various applications, from construction sites to warehouse logistics.
- Reduced downtime with top-of-the-line components and engineering.
Possible Use Cases ποΈ
- Construction: Perfect for high-rise metal structures, heavy beam installation, and more.
- Logistics: Ideal for loading and unloading large shipments effortlessly.
- Maintenance: Efficient for large-scale facility maintenance and repairs.
Don't miss out on the opportunity to enhance your operations with one of the most reliable and powerful crane-truck combinations available. If you're looking for efficiency, strength, and innovative design, this is the solution for you!
Act now and elevate your operational capabilities with this incredible machine! π
