2019 Kubota KX080 Excavator Backhoe – Powerful, Precise & Built to Perform
Posted Date: Jul 13th, 2025 at 04:34 AM
0.0 star 139 views
Price: $79500.00
🚜 2019 Kubota KX080 Excavator Backhoe – Powerful, Precise & Built to Perform
Strong Digging Force | Smooth Controls | Ideal for Mid-Sized Excavation Jobs
πŸ”§ Machine Overview – Kubota KX080
  • Make/Model: Kubota KX080
  • Year: 2019
  • Operating Weight: Approx. 17,350 lbs (7,870 kg)
  • Engine: Kubota V3800 Turbo Diesel – Tier 4 Final Compliant
  • Horsepower: 74 HP (55 kW)
  • Max Dig Depth: Approx. 14 ft 5 in (4.4 m)
  • Max Reach: Approx. 21 ft 5 in (6.53 m)
  • Tail Swing: Conventional or reduced tail swing (specify exact)
  • Tracks: Steel tracks for durability and traction
πŸ› οΈ Performance & Features
  • Hydraulic System:
    • Responsive and smooth hydraulics for precise control
    • Factory auxiliary hydraulics for powering attachments like breakers and thumbs
  • Durability:
    • Heavy-duty boom and arm designed for tough jobs
    • Reinforced undercarriage built to handle rugged terrain
  • Fuel Efficiency:
    • Tier 4 Final engine with improved fuel economy and reduced emissions
    • Auto-idle and low-maintenance design for cost savings
πŸ‘¨β€πŸ’» Operator Comfort
  • Cab:
    • Spacious, ROPS/FOPS certified cab with excellent visibility
    • Climate control with heating and air conditioning (if equipped)
  • Controls:
    • Ergonomic joystick controls with easy-to-read displays
    • Adjustable seat for operator comfort during long shifts
βœ… Ideal Applications
  • Mid-sized excavation and site development
  • Utility trenching and pipe laying
  • Landscaping and grading
  • Demolition and material handling
  • Farm and ranch maintenance
πŸ” Condition & Inclusions
  • Condition: Well-maintained, fully operational
  • Undercarriage: [Insert % wear or recent service details]
  • Includes:
    • Standard digging bucket
    • Auxiliary hydraulic plumbing
    • Quick coupler (if applicable)
  • Title: Clean and transferable
πŸ’° Pricing & Financing
  • Priced competitively for the 8-ton excavator segment
  • Financing available (OAC)
  • Delivery options available nationwide
  • Trade-ins accepted
πŸ”§ Why Choose the 2019 Kubota KX080?
  • Trusted Kubota reliability and proven performance
  • Powerful engine with clean emissions technology
  • Comfortable operator cab with modern features
  • Versatile machine suited for a wide range of applications
