2019 Ford F-550 XL – Picker Crane with Fassi F-65 Boom
Posted Date: Aug 5th, 2025 at 04:48 AM
0.0 star 153 views
Heavy-Duty | Precision Lifting | Work-Ready Unit
🔧 Truck Specifications:
  • Make/Model: Ford F-550 XL
  • Year: 2019
  • Engine: 6.7L Power Stroke V8 Turbo Diesel – robust power for heavy-duty lifting and hauling
  • Transmission: TorqShift 6-speed automatic
  • Drive: Dual Rear Wheel (DRW) for enhanced stability and load capacity
  • GVWR: [Confirm – typically around 19,500 lbs]
  • Cab: Spacious XL trim cab with ergonomic controls, A/C, and durable interior
🔧 Crane Specifications:
  • Brand/Model: Fassi F-65
  • Type: Hydraulic articulating picker crane with knuckle boom
  • Max Lifting Capacity: Approximately 14,000 lbs (depending on boom extension and configuration)
  • Boom Reach: Approx. 40+ ft horizontal reach for versatile placement
  • Controls: Hydraulic controls with remote operation for precise, safe handling
  • Strong and reliable Ford F-550 XL chassis designed for vocational crane work
  • Fassi F-65 boom for flexible, high-capacity lifting tasks
  • Dual rear wheels for increased stability during lifts
  • Outriggers for enhanced safety and stability on job sites
  • Spacious cab designed for operator comfort during long shifts
  • Maintained and ready for immediate deployment
  • Construction and building material handling
  • Utility and municipal service
  • Industrial lifting and equipment placement
  • Heavy-duty picker crane operations
