2019 Ford F-550 DRW XLT Crew Cab – Effer 80 Knuckle Boom Truck
Posted Date: Aug 5th, 2025 at 04:45 AM
0.0 star 125 views
Price: $89900.00
Heavy-Duty | Precision Lifting | Work-Ready Unit
🔧 Truck Specifications:
  • Make/Model: Ford F-550 DRW XLT Crew Cab
  • Year: 2019
  • Engine: 6.7L Power Stroke V8 Turbo Diesel – high torque for superior hauling and lifting
  • Transmission: TorqShift 6-speed automatic
  • Drive: Dual rear wheel (DRW) heavy-duty configuration for maximum stability
  • GVWR: [Confirm – typically around 19,500 lbs for this configuration]
  • Cab: Spacious crew cab with premium XLT trim, seating for up to 6, power accessories, touchscreen infotainment, A/C, and comfort features
🔧 Crane Specifications:
  • Brand/Model: Effer 80 Knuckle Boom
  • Type: Hydraulic articulating knuckle boom crane
  • Max Lifting Capacity: [Confirm – typically in the 12,000–15,000 lb range for this model]
  • Boom Reach: [Confirm exact spec – generally 30–40+ ft horizontal reach]
  • Controls: Smooth hydraulic operation with manual or remote control options
  • Condition: Fully operational, well-maintained, ready for immediate use
  • Strong Ford F-550 XLT chassis with heavy-duty DRW setup for stability under crane operations
  • Effer 80 knuckle boom for precise, versatile lifting and material placement
  • Crew cab seating – transport your entire work crew comfortably
  • Outriggers for superior lifting stability
  • Ample flatbed space for tools, equipment, or materials
  • Maintained and ready for immediate work
  • Construction material delivery and placement
  • Utility and municipal work
  • Industrial equipment transport
  • Service and maintenance requiring both crew transport and lifting capacity
