2018 Platform / Boom Truck / Crane
Posted Date: Aug 5th, 2025 at 04:51 AM
0.0 star 155 views
Versatile | Heavy-Duty | Work-Ready Unit
🔧 Truck Specifications:
  • Year: 2018
  • Type: Platform truck equipped with boom and crane
  • Engine: [Confirm make/model & horsepower] high-performance diesel engine
  • Transmission: [Confirm manual or automatic]
  • Drive: [Confirm 4x2, 4x4, or tandem axle configuration]
  • Cab: Comfortable cab with ergonomic controls and essential features
🔧 Crane/Boom Specifications:
  • Type: Hydraulic boom and crane system
  • Max Lifting Capacity: [Confirm capacity – typically between 5,000 to 30,000+ lbs depending on model]
  • Boom Reach: [Confirm reach – often 30–60+ ft]
  • Controls: Hydraulic controls with remote operation option for precision and safety
  • Condition: Fully operational, maintained, and work-ready
  • Multi-functional platform with boom and crane for versatile lifting and placement
  • Durable construction designed for heavy-duty industrial and construction use
  • Stable lifting with outriggers and advanced control systems
  • Spacious cab designed for operator comfort during long shifts
  • Ready for immediate deployment on diverse job sites
  • Construction and infrastructure projects
  • Utility and municipal service work
  • Heavy equipment placement and transport
  • Industrial lifting and maintenance operations
