2017 International 7600 – 16’ Dump Truck with HIAB Knuckle Boom Crane
Posted Date: Jul 9th, 2025 at 05:28 AM
0.0 star 197 views
Price: $168530.00
🚧 2017 International 7600 – 16’ Dump Truck with HIAB Knuckle Boom Crane
Heavy-Duty Material Handling | Dual Function: Dump + Lift | Built for Demolition, Construction & Utility Work
πŸ› οΈ Truck Overview – 2017 International 7600
  • Engine: Cummins ISM 10.8L Diesel – 370–400 HP range, proven for high torque and load capability
  • Transmission: Eaton Fuller 18-Speed Manual – Built for serious hauling, full control over terrain and load
  • Drivetrain: Tandem axle, 6x4 configuration
  • GVWR: Approx. 66,000 lbs – Legal, high-capacity for heavy-duty jobs
  • Mileage: [Insert current miles] – Fleet maintained, full service history available
  • Fuel Tanks: Dual aluminum tanks – Long-haul ready
  • Brakes: Air brakes with automatic slack adjusters
  • Suspension: Hendrickson or International heavy-duty suspension – Smooth under load
  • Cab Features:
    • Clean, well-kept day cab
    • A/C, AM/FM stereo, cruise control
    • Air-ride driver’s seat, tilt/telescopic steering
    • PTO controls and crane panel inside cab
πŸ—οΈ HIAB Knuckle Boom Crane – Side-Mounted
  • Make/Model: HIAB 144, 166, or equivalent (confirm exact model)
  • Lifting Capacity: Approx. 10,000–12,000 lbs max lift (varies by boom length and reach)
  • Boom Reach:
    • Horizontal Reach: Up to 30–40 ft
    • Vertical Reach: Ideal for 2–3 story lifts
  • Boom Type: Articulating knuckle boom for precise placement in tight spaces
  • Controls:
    • Remote control OR manual side levers
    • Load-limiting system and stability sensors
  • Stabilizers: Hydraulic outriggers with wide stance – Keeps truck stable even when fully loaded
  • Perfect for:
    • Loading/unloading heavy pallets, concrete forms, rebar, pipe, demolition debris
    • Urban construction zones or confined site work
πŸš› Dump Body Specs – 16-Foot Steel Bed
  • Body Type: High-tensile steel dump with reinforced sides
  • Length: 16 ft | Height: 3–4 ft sidewalls
  • Hoist: PTO-powered scissor lift or telescopic hydraulic hoist – Strong and fast-acting
  • Tailgate: Swing or barn-door style with locking latches
  • Condition: Clean bed, no rust-through, solid floor
  • Tie-downs: Welded D-rings and bulkhead protection for crane lifts
βœ… Applications
  • Demolition debris transport + site cleanup
  • Construction material delivery & retrieval
  • Utility work: pipe, pole, transformer transport
  • Heavy landscaping & tree removal
  • Equipment rental yards with self-loading/offloading needs
  • Municipal & public works departments
πŸ” Condition & Extras
  • Year: 2017
  • Mileage: [Insert actual miles]
  • Tires: 70%+ tread – All matching
  • Crane Condition: Fully functional, inspected, and load tested
  • Dump Bed: Tight hydraulics, no leaks, recently serviced
  • Clean Title – No salvage, lien-free
  • DOT Ready: Meets all safety and operational standards
πŸ’° Pricing & Delivery
  • Competitively priced for dump + crane combo
  • Nationwide delivery available
  • Trades accepted – ask about other inventory
πŸ”§ Why This Truck Stands Out
  • Dual-function unit: One truck handles both dump and crane duties
  • Manual 18-speed transmission: Excellent for hilly routes, jobsite crawling, and load control
  • HIAB = Trusted brand for articulation, reliability, and power
  • Heavy-duty spec: Perfect for contractors needing a versatile, self-sufficient vehicle
  • Fleet-ready: Add to your lineup or replace two trucks with one
