2017 Bobcat E35i Mini Excavator β Compact, Efficient, and Easy to Operate
Posted Date: Jul 13th, 2025 at 04:27 AM
Price: $48500.00
π 2017 Bobcat E35i Mini Excavator β Compact, Efficient, and Easy to Operate
Zero Tail Swing | Smooth Controls | Perfect for Landscaping, Utility, and Residential Work
π§ Machine Overview β Bobcat E35i
Make/Model: Bobcat E35i
Year: 2017
Operating Weight: Approx. 7,400 lbs (3,356 kg)
Engine: Kubota D1105 β Tier 4 Final Compliant
Horsepower: 24.8 HP (18.5 kW)
Max Dig Depth: 11 ft 5 in (3.5 m)
Max Reach: 17 ft 3 in (5.25 m)
Tail Swing: Zero tail swing β ideal for working in tight and confined spaces
Tracks: Rubber tracks for minimal ground disturbance
π οΈ Performance & Features
Hydraulic System:
Smooth, load-sensing hydraulics for precise control
Factory-installed auxiliary hydraulics for attachments like breakers and augers
Fuel Efficiency:
Kubota Tier 4 Final engine with low emissions and excellent fuel economy
Auto-idle feature reduces fuel consumption during idle periods
Operator Controls:
Intuitive joystick controls with ergonomic layout
LCD display showing machine diagnostics, fuel level, and service alerts
π¨βπ» Operator Comfort
Cab:
Spacious, ROPS-certified cab with excellent visibility
Optional enclosed cab with heating and air conditioning available
Seat: Adjustable suspension seat to reduce operator fatigue
Noise Reduction: Engine and cab designed for quieter operation
β Ideal Applications
Residential and commercial landscaping
Utility trenching and repair
Light demolition and site prep
Farm and rural property maintenance
Equipment rental fleets
π Condition & Inclusions
Hours: [Insert actual hours]
Condition: Well-maintained, job-ready
Undercarriage: [Insert wear % or recent maintenance info]
Includes:
Standard digging bucket
Auxiliary hydraulic plumbing
Quick coupler compatibility
Title: Clean and transferable
π° Pricing & Financing
Competitively priced in the 3.5-ton mini excavator class
Financing options available (OAC)
Delivery options across the region or nationwide
Trade-ins accepted
π§ Why Choose the 2017 Bobcat E35i?
Zero tail swing design for tight jobsite maneuvering
Reliable Kubota engine with excellent fuel efficiency
Operator comfort and easy controls for long shifts
Strong resale value and wide dealer support
