2016 Elliott Boom Truck Crane – High Reach. Heavy Lift. Built for Productivity.
Posted Date: Jul 8th, 2025 at 10:35 PM
0.0 star 171 views
🏗️ 2016 Elliott Boom Truck Crane – High Reach. Heavy Lift. Built for Productivity.
Versatile Workhorse | Sign Installation | Construction | Utilities | Maintenance
🚛 Truck & Chassis Overview
  • Chassis Make: Typically Freightliner / Peterbilt / International (confirm actual make & model)
  • Engine: Cummins ISL / PACCAR PX-9 / or Detroit DD13 – Reliable, fuel-efficient diesel engines
  • Transmission: Allison Automatic or Eaton Fuller Manual – Smooth, dependable, jobsite-ready
  • Axle Configuration: Tandem Axle (6x4) for balance, payload, and stability
  • GVWR: Approx. 54,000 – 66,000 lbs (varies by spec)
  • Cab Features:
    • Clean, air-ride driver’s seat
    • PTO switch and crane function display
    • Cold A/C, AM/FM stereo, and power accessories
  • Mileage: [Insert actual miles] – Low-mileage, well-maintained fleet unit
  • Fuel Tanks: Dual tanks – long range without constant refueling
🏗️ Crane Specs – Elliott HiReach or BoomTruck Series
  • Model: Elliott 36105F, 40142, 45127 or equivalent (confirm model)
  • Lifting Capacity: Up to 36,000–45,000 lbs (depending on model)
  • Boom Reach:
    • Main Boom: 105–142 ft
    • Jib Extension (if equipped): Up to 200 ft total working height
  • Crane Type: Telescopic boom with fixed or rotating turret
  • Rotation: 360° continuous rotation with hydraulic swing
  • Winch: 2-speed winch with up to 15,000 lbs line pull
  • Crane Controls:
    • Dual seated cab or stand-up ground controls
    • Optional wireless remote for single-operator convenience
    • Load Moment Indicator (LMI) & anti-two-block system
  • Stability: Full-span hydraulic outriggers with automatic leveling (if equipped)
  • Optional Work Platform / Man Basket: OSHA-compliant, hydraulically rotating
🔩 Bed & Body Setup
  • Bed Length: 20–24 ft steel flatbed with non-slip deck
  • Deck Features:
    • Welded D-rings, load binders, stake pockets
    • Built-in ladder access
    • Steel headache rack
  • Tool Storage: Optional side compartments or underbody toolboxes
  • Condition: Clean, dent-free, crane mounts reinforced, ready to work
Best For:
  • Commercial sign installation & maintenance
  • Construction & steel erection
  • Utility pole installation & power line work
  • Tree service & maintenance
  • Industrial maintenance crews and city service fleets
  • Crane rental fleets and subcontractors needing boom flexibility
🔍 Condition & Highlights
  • Year: 2016
  • Crane Hours: [Insert crane usage if known]
  • Tires: 70–85% tread, DOT-compliant
  • Hydraulics: Fully functional, load tested
  • Title: Clean title, no salvage or damage history
  • Inspection: Ready for jobsite or fleet use
💰 Pricing, Delivery & Financing
  • Priced competitively against Altec, Terex, and National Crane alternatives
  • Financing available (OAC) – flexible terms
  • Nationwide shipping available – fast and insured
  • Trade-in and package fleet deals available
🔧 Why Elliott?
  • Industry leader in high-reach boom trucks – Trusted by sign, utility, and lift operators nationwide
  • Built in the USA – Superior quality, long service life, excellent support
  • Durable design + smart controls – Made for daily use on tough jobs
  • High resale value – Proven brand with strong aftermarket demand
