2016 CASE CX250D Excavator – Built for Speed, Strength & Fuel Efficiency
Posted Date: Jul 15th, 2025 at 02:51 AM
0.0 star 183 views
Price: $134900.00
🚧 2016 CASE CX250D Excavator – Built for Speed, Strength & Fuel Efficiency
Tier 4 Final | Advanced Hydraulics | Ideal for Mid-to-Large Scale Construction Projects
🔧 Machine Overview – CASE CX250D
  • Make/Model: CASE CX250D
  • Year: 2016
  • Operating Weight: Approx. 56,900 lbs (25,811 kg)
  • Engine: Isuzu 6HK1-TCC – Tier 4 Final Emissions Compliant
  • Horsepower: 177 HP (132 kW)
  • Max Dig Depth: 21 ft 10 in (6.65 m)
  • Max Reach at Ground Level: 32 ft 5 in (9.88 m)
  • Bucket Capacity: Up to 1.57 cu. yd. depending on setup
  • Undercarriage: Long Carriage (LC) – reinforced for added lift and digging stability
🛠️ Performance & Efficiency
  • Hydraulic System:
    • Advanced Intelligent Hydraulic System (IHS) for faster cycle times
    • Auto Power Boost and Heavy Lift modes for extra digging force when needed
    • Smooth, responsive multi-function controls for better operator precision
  • Fuel Efficiency:
    • Tier 4 Final engine with SCR-only system (no DPF) for low maintenance
    • Auto idle, shutdown, and work mode selection to reduce fuel usage
  • Cooling System:
    • Improved cooling-on-demand with radiator, oil cooler, and intercooler separation
👨‍💻 Operator Comfort & Technology
  • Cab:
    • Spacious, pressurized cab with ROPS/FOPS certification
    • Climate control with AC and heat
    • Excellent visibility with large windows and low-profile monitors
  • Controls & Monitoring:
    • 7-inch full-color monitor with machine diagnostics and settings
    • Adjustable work modes and operator preferences
    • Rear-view camera standard; optional side cameras
✅ Ideal Applications
  • Earthmoving and trenching
  • Road and bridge work
  • Commercial site prep and mass excavation
  • Utility and pipeline digging
  • Quarry and material handling
🔍 Condition & Inclusions
  • Condition: Excellent; ready for work
  • Undercarriage: [Insert wear % or maintenance details]
  • Includes:
    • Heavy-duty digging bucket
    • Quick coupler (if applicable)
    • Auxiliary hydraulic lines for attachments
  • Title: Clean and available
💰 Pricing & Financing
  • Competitively priced for a 25-ton class excavator
  • Financing available (OAC)
  • Delivery available across North America
  • Trade-ins welcome
🔧 Why Choose the 2016 CASE CX250D?
  • Faster cycle times and reduced fuel consumption
  • Operator-friendly cab with advanced control features
  • Durable components and simplified maintenance
  • Ideal mix of power, precision, and efficiency in its class
📞 Ready to put this CASE CX250D to work? Contact us now for pricing, availability, or financing options.
